Embedded support for LMM within SPIN (discussion & proposals)
Support for some type of LMM within the SPIN Interpreter - discussion and ideas
The following is copied from the thread :
IDE for linux / Mac (and Windows) users - Ver 0.14 - The "Yet another" release··(page 19)
http://forums.parallax.com/showthread.php?p=755835
Prop Tools under Development or Completed (Index)
http://forums.parallax.com/showthread.php?p=753439
cruising][noparse][[/noparse]url=http://www.bluemagic.biz]cruising[noparse][[/noparse]/url][/url]
This is a [noparse][[/noparse]b]bold[noparse][[/noparse]/b] test.
BradC said...
Its interesting you bring this up. I've been playing with and pondering the addition of a "BAS" block with a PBASIC syntax-ish style. I had envisioned a helper cog, perhaps in an LMM style that dropped pre-defined blocks together, something along the lines of SX/B to enable a "BASIC" on the Propeller. So I don't believe we are way out of line in our thinking.
Mike Green said...
Here's a previous thread where I mentioned a native Prop compiler-compiler and the beginnings of a Basic compiler. I really have not worked on it much since this was posted other than to look at the possibility of compiling into Spin byte codes rather than LMM object code.
Cluso99 said...
...there is room in my ClusoInterpreter (not finally debugged...) to possibly add LMM. Basically I have LMM (basic style) currently in my interpreter (as a zero footprint debugger). Anyway ... we would need the compiler to be modified for this and there are two versions out there that the writers could modify.
One caveat - LMM variables have to be in hub unless the ClusoInterpreter is specifically compiled with overlays, or with features removed.
BradC said...
I like the idea of adding LMM support to the compiler.·... I just need to sit down with someone and dedicate some time to understanding precisely what it is that you have in mind and how it needs to be put together...
Ale said...
Maybe just adding some macro support can help with the LMM support.
I'm writting a simple user interface, config panels, with 4 or 5 "controls". All drawing is made native in pasm, user inut and responses are done in LMM: relative jump, constant loading, subroutine call to LMM code, just 5 routines. It gets... complicated I mean there are loads of:...
call··#krnl_loadcnt
long·@k4_cnt_FONT+(krnl_r0<<26)+16
call·#krnl_call
long··@lmm_config+16
and other niceties (with the scheme I proposed some time ago). but, it works. Some macros could easily help and make the code a bit more flexible without fixing the compiler to a specific lmm type. (I thought for my compiler to do some sort of find-and-replace method, just for simplicity).
Let the discussion begin...Cluso99 said...
@Ale:
The LMM (interpreter) that I implemented in the debugger uses 5 longs: 4 for the loop and execution and 1 for data. However, the actual LMM code is more complex because it has to take care of jumps.
A call to an LMM routine would make sense for the interpreter to implement. The completion of the LMM would then just be another fixed call to return to the interpreter. I could see this as being relatively easy to implement from both the interpreter and the compilers perspectives. The main complexity is the fact that mov instructions will not work as expected because variables are not in cog memory. This means it is not true LMM, but a variant or subset. However, I could see some real speed advantages of mixing spin and LMM.
'Just a few PropSTICK Kit bare PCBs left!
There are certain routines in the interpreter that I am sure are used less often, such as multiply, divide, square root. This would free quite a bit of code space for variables to be stored within the cog. I even think this would be good for spin.
If spin were in LMM, it would run around 4 times slower. The reason for this is that the LMM code could be written in reverse, so the sweetspot could be hit. If spin were in LMM, it would run around 8 times slower. This is because the sweetspot cannot be hit (see below).· See Phil's and my comments below. We can hit the sweetspot for LMM (in reverse) for dual fetching yielding 4 times slower than pasm. The decoding would probably be similar in timing as I am using a lookup table held in hub. However, some routines could be rolled out to deliver speed gains, but at the expense of hub memory.
My ClusoInterpreter is showing a likely performance increase of 25-30%, so we have that gain to begin with. The mathematic routines are now very tight and much faster than previously, so they will be· 4 · 8 ··4 times slower than my version. I get a huge gain here.
A mix of pasm, overlays and LMM for the interpreter could be a good mix. Sounds like an interesting challenge
Postedit: I was just checking the execution loop. It will be around 8 times slower for LMM as it is not possible to catch the hub in the sweetspot, so it will be 32 cycles for each LMM instruction. The loop is: The simple loop for forward LMM takes 32 cycles and is shown below:
Postedit: Here is reverse LMM execution loop in 16 cycles per LMM
Post Edited (Cluso99) : 12/22/2008 8:24:15 PM GMT
Whilst he's at it he could introduce an LMM block to contain hand coded LMM.
Given the rate at which Brad works he could probably have this up and running whist everyone is sleeping off their Christmas dinner [noparse]:)[/noparse]
I guess my serious point is to not introduce yet another language, Basic, Forth or whatever but to use the one we already know and love. C has already been done.
Post Edited (heater) : 12/22/2008 3:36:50 PM GMT
Damn. I hadn't seen this thread. You alerted me to the fact that the sweetspot could be hit by dual fetches in reverse and that is what I used in my overlay loader.
Assembly Oververlay Loader for Cog FAST (renamed & released)
http://forums.parallax.com/forums/default.aspx?f=25&m=272823
One thing to keep in mind is the dual fetch/execute and it's impact on any jumps. I have not read the whole article yet, but it looks interesting.
Don't forget though that a large Spin VM written in LMM takes away Hub memory ( quite quickly ) which would be used by your Spin program.
So ... Minimal footprint Spin VM running the LMM from external I2C Eeprom. Slower still but maximum RAM for Spin code. Would need a mechanism to get the LMM into that Eeprom space which may have to be separate to any user I2C.
Afraid I don't have any time at present to get involve din Prop development.
I like the idea of an LMM-based Spin interpreter in ROM with some means of easily switching from PASM intepreter to LMM interpreter or other mechanism for extensibility. Not sure how that would fit though with protecting the IP Rights of such an interpreter. I get the impression that the Spin interpreter will be more protected in the Prop II.
I asked off the record a little while back, and received the reply that the intention was the interpreter would be made available similar to the current one.
Cardinal Fang! Fetch the comfy chair.
If it doesn't I doubt it would be the end of the world. I'm sure what we have can be stretched into what will be and we'll have third party Spin interpreters if needed.
Either way we can complain about not having the challenge of reverse engineering and decoding the new interpreter or that the effort is too hard
