PLL Problems?
I was messing with my protoboard the other day and replaced the 5MHz xtal with a 6MHz one and it ran fine with a 16x pll, but when I try to use the 6MHz xtal with another one of my projects that uses the 40-pin DIP version, it won't run @ 16x pll. If I tell it the xtal is 12MHz (double) and 8x pll (half), it works fine. As far as I know the chip has lived a sheltered life and not been over-voltaged or static zapped.
The program I was using to test just set a pin as an output to turn on an LED. Worked fine on the protoboard, but on the 40pin it acted as described above.
Any ideas?
Any ideas?
