syncronise 3 dc motors with basicstamp
Hi,
I want to use the basicstamp for syncronising 3 dc motors, I use a L298 Driver as driver for the DC motor every motor have a encounter
For every 180 degrees rotation i receive a puls.
for every motor i use :
pin 1 for the direction (clockwise cclockwise)
pin 2 start and stop
pin 3 for input of the pulses
Wat is the best way for programming this, where can i find a example?
·· MV
·· MV
For syncing 3 motors, I think you would start by getting a code that would start and stop the motors properly, then move to syncing them. For sync at low speeds, I think 180 degrees is a rather small pulse rate, but may be doable. You may want to have one motor be designated as the master, in which case the other encoder pulses are compared, and the L298 adjusted to compensate for the error on the slaves. Although, I can't really see how it is you are using speed control with a single Stamp, you will need some variation of speed control to sync the motors, even if that sync is very short 'stops' on the L298.
Yes a driving each motor with a separate L298 driver. And each motor have an encounter that outputs a pulse every 180 degrees.
I use now for
motor1 motor2 motor 3
pin 1 pin4 pin 7 for the direction
pin 2 pin5 pin 8 start and stop
pin 3 pin6 pin 9 for input of the pulses
It is for syncing by low speed. I d'ont now of is it possible with a basicstamp.
- Stephen
