extra power for boe-bot servos
I want to provide a separate power source to·my servos on the boe-bot.· I see that there is a jumper between the X4 and X5 servo connections.· If I decide to add a 6 volt supply to just power the servos, would I connect the positive wire to Vin of the jumper and would·I connect·ground·Vss on my board?
If it were me, I'd just use a larger 6V battery pack to power everything through the power jack. If you have two separate supplies, you also need a switch for the second supply.
for 4 AAs that'd be 6 volts.
Make sure that you do not use a 9volt battery if you choose to do this. The servos can't handle 9 volts. I THINK they are
rated for 7.2 volt max, but don't hold me to it.
If you want to completely isolate the servo power from the BS2 then don't use the jumper at all. Connect your own
wire to the center pin of the jumper and then connect it to the + on your battery pack and connect the - of the pack to
VSS on the BOE.
As Mike said, its vital not to connect your battery pack to VDD or VIN on the BOE. This includes accidently touching it against
the top or bottom pin of the jumper.
You can then use a 9volt or 4xAA battery pack to power the BOE as normal.
