Charlieplexing with the BS2
Hey everyone, I've started a project where I'm charlieplexing 64 LED's using 9 pins on my BS2.· I wanted to start a discussion about how I should program this display.· My thought is to do a simple lookdown table with the OUTS and DIRS commands, but I wonder if there is enough space to store the entire program.· My goal is to use ONLY a BS2 (no external hardware)·to run my display because I'm broke.· I'll post a sample program as soon as I find time to write one.
Thanks in advance for the help!
· -- Carl, nn5i@arrl.net
Thanks for the link Mr.Allen!!!!
____________$WMc%________Merry Xmas
The Truth is out there
It depends on how many of the 64 LEDs need to be "ON" at any given time.
If alot of them have to appear to be on together, then the BS2 is probably not fast enough. You will get flickering.
On the other hand, if you only need 1 or 2 on at a time, then it will probably work okay.
Bean.
"The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
www.iElectronicDesigns.com
