Dead on Arrival Unit?
I received my Hydra this weekend but I think it is dead.
All i get on the screen is some random looking black and white lines. It actually looks like there is no sync signal. I tried two different TVs, three different cables and I also tried the 128K cartridge...in case it was a software bug. The cart gives a different looking random pattern, but still not viewable.
Any ideas on other things to try? BY the way, my Prop Demo board works fine on these TVs.
as the clocks are different.
the hydra has a 10Mhz clock, that you use PLL*8 to get 80Mhz
and the demoboard is 5Mhz and PLL*16 to get 80Mhz
I just pulled mine out and tried the HYDRA and got the weird horizontal lines you were talking about.
·</Parallel Universe>
There are two programs I am using to test on both tvs.
1. The default program that ships with the Hydra (asteroids like)
2. The default program that ships on the 128K game cartridge.
Both programs produce similar results, which look like a display that cannot sync to the incoming signal.
OR, have you tried programming it with something? as IIRC there was some issues with batches of unprogrammed carts.
I thought maybe the unit was not preprogrammed, but then I thought the odds of a hydra AND the cart not being programmed were pretty slim.
Pretty much anything in the \demos section should work perfectly.
Might mean a call to Parallax in the morning..
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 12/16/2008 1:58:19 PM GMT
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Best regards,
Dave
Dave Andreae
Parallax Tech Support·
Ok, you've had a working Hydra for two days.. where's the new games? <SMIRK>
The Hydra is an awesome kit for learning Spin/Game Programming.
Congrats on getting it running, now use your Parallax credit to get an SDmax card
when you return the dead one.. [noparse]:)[/noparse]
OBC
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Anre'
