Radio Control BoeBot
I have been creating different things with my BoeBot Kit for a while now and looking to try something more advanced.
I want to create a robot that can go from autonomous to RC controlled and I am looking for someone who has done this and has already outlined the project before I buy any expensive parts.
I already have a robot chassis with 2 motors. I want to buy a motor controller and use my RC radio to control the whole thing.
I have played with my RC radio set and am able to pick up signals from the receiver and do certain things, but many motor controllers like Pololu Trex have RC hook-ups to all the RC channels (if needed) and channel 5 toggles between autonomous (serial) and RC.
This sounds just like what I want to do. Has anyone used this, and extra things I need to know about before buying my parts?
Can someone vouch for the Pololu trex? what rc radio set did you use?
Justin
Justin
Take a look at the attached UAV BS2p code as an example.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
··· I have done something simillar using an old RC transmitter and reciever, a BS2, and a pololou dual·micro motor controller.· I used the BS2 to read the outputs of the reciever with the PULSIN in command, and then scaled the time from 0 to 127, so that I could send that value to the motor controller for the speed of each motor (right and left wheel).· If the BS2 did not see any activity on the throttle line the bot would switch to autonomous mode, and use a Ping )))·sensor to roam the room.· As soon as the BS2 reconized me pulling the throttle trigger it would switch back to manual mode.
··· The·drivetrain I used was a set of Tamiya gear boxes with three volt motors.· It was pretty cool, but now I am switching it over to a PS2 controller and using the RF transmitter package from Parallax.· If you have 2 BS2s you can use one to read the PS2 controller and send data with the transmitter, and· have·the other·BS2 with the reciever on the bot.· This is a little more expensive setup, but you will have more options.· I will get some pics posted as soon as I can.
Hope I was of some help, JJ.
PS2 controll with RF is a work in progress, but I should have a rough draft done tonight.
There are 10 types of people that understand binary, those who do, and those who don't.
Post Edited (JJ) : 12/18/2008 2:57:57 AM GMT
' File:PS2_Controller_RF.bs2 ' Author:Justin Jordan ' Date:12-17-08 ' {$STAMP BS2} ' {$PBASIC 2.5} ' {$PORT COM5} '----Program Description------------------------------------------------------- 'Read data from a PS2 Dualshock controller 'and send DATA to robot using RF modules. 'Based off code written by John Williams. '----PIN Declaration----------------------------------------------------------- Clk PIN 0 Att PIN 1 Cmd PIN 2 Dat PIN 3 RF_txmt PIN 15 '----Constants----------------------------------------------------------------- Bps CON 84 '----Variables----------------------------------------------------------------- 'For PS2 controller psxout VAR Byte psxin VAR Byte psxid VAR Byte psxstatus VAR Byte switches0 VAR Byte switches1 VAR Byte rjoystick_x VAR Byte rjoystick_y VAR Byte ljoystick_x VAR Byte ljoystick_y VAR Byte idx VAR Nib 'For Motor Controller speed0 VAR Byte speed1 VAR Byte motor0 VAR Byte motor1 VAR Byte '----EEPROM DATA--------------------------------------------------------------- '----Initialization------------------------------------------------------------ DEBUG CLS DIRA = %0111 '----Program Code--------------------------------------------------------------- Main: DO GOSUB Get_Data 'Get PS2 Data IF rjoystick_y > 154 THEN speed0 = rjoystick_y*/$0144 -195 'Calculate rev speed0 motor0 = 0 ELSEIF rjoystick_y < 101 THEN speed0 = -(rjoystick_y*/$0144) + 127 'Calculate Fwd speed0 motor0 = 1 ELSE speed0 = 0 ENDIF IF ljoystick_y > 154 THEN speed1 = ljoystick_y*/$0144 -195 'Calculate rev speed1 motor1 = 2 ELSEIF ljoystick_y < 101 THEN speed1 = -(ljoystick_y*/$0144) + 127 'Calculate Fwd speed1 motor1 = 3 ELSE speed1 = 0 ENDIF PULSOUT RF_txmt, 1200 SEROUT RF_txmt, Bps, [noparse][[/noparse] "#", motor0, speed0, motor1, speed1, switches0, switches1] LOOP '----Subroutines--------------------------------------------------------------- Get_Data: LOW Att psxout = $01 : GOSUB PSX_TxRx psxout = $42 : GOSUB PSX_TxRx psxid = psxin psxout = $00 : GOSUB PSX_TxRx psxstatus = psxin GOSUB PSX_TxRx : switches0 = psxin GOSUB PSX_TxRx : switches1 = psxin GOSUB PSX_TxRx : rjoystick_x = psxin GOSUB PSX_TxRx : rjoystick_y = psxin GOSUB PSX_TxRx : ljoystick_x = psxin GOSUB PSX_TxRx : ljoystick_y = psxin HIGH Att RETURN PSX_TxRx: FOR idx = 0 TO 7 Cmd = psxout.LOWBIT(idx) Clk = 1 psxin.LOWBIT(idx) = Dat Clk = 0 NEXT RETURN DEBUG "psxid = ", HEX psxid, CLREOL,CR, 'Move inside loop for troubleshooting "psxstatus = ", HEX psxstatus, CLREOL, CR, "Lft, Dwn, Rgt, Up, Start, Joyr, Joyl, SELECT = ", BIN8 switches0, CR, "sq, x, cir, tri, R1, L1, R2, L2 = ", BIN8 switches1, CR, "Rjoystick_X = ", DEC rjoystick_x, CLREOL, CR, "Rjoystick_Y = ", DEC rjoystick_y, CLREOL, CR, "Ljoystick_X = ", DEC ljoystick_x, CLREOL, CR, "Ljoystick_Y = ", DEC ljoystick_y, CLREOL, CR, "Speed0 = ", DEC speed0, CLREOL, CR, "Speed1 = ", DEC speed1, CLREOL, CR DEBUG HOME▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
' File:RF_Bot ' Author:Justin Jordan ' Date:12-17-08 ' {$STAMP BS2} ' {$PBASIC 2.5} ' {$PORT COM4} '----Program Description------------------------------------------------------- 'Recieve Data using RF modules to control robot. '----PIN Declaration----------------------------------------------------------- RF_recv PIN 13 Reset PIN 14 M_Data PIN 15 '----Constants----------------------------------------------------------------- Bps CON 84 '----Variables----------------------------------------------------------------- motor0 VAR Byte speed0 VAR Byte motor1 VAR Byte speed1 VAR Byte switches0 VAR Byte switches1 VAR Byte '----EEPROM DATA--------------------------------------------------------------- '----Initialization------------------------------------------------------------ DEBUG CLS HIGH M_Data LOW Reset HIGH Reset PAUSE 1000 '----Program Code--------------------------------------------------------------- Main: DO SERIN RF_recv, Bps, [noparse][[/noparse]WAIT ("#"), motor0, speed0, motor1, speed1, switches0, switches1] IF switches1.BIT4 = 0 THEN 'Reset Motor controller Reset = 0 ELSE Reset = 1 ENDIF SEROUT M_Data, Bps, [noparse][[/noparse]$80,0,motor0,speed0] 'Send data to motor controller SEROUT M_Data, Bps, [noparse][[/noparse]$80,0,motor1,speed1] LOOP '----Subroutines--------------------------------------------------------------- DEBUG DEC motor0,CR,CLREOL, 'Move inside loop for troubleshooting DEC speed0,CR,CLREOL, DEC motor1,CR,CLREOL, DEC speed1,CR,CLREOL, BIN8 switches0, CR, CLREOL, BIN8 switches1, CR, CLREOL DEBUG HOME·
Post Edited (JJ) : 12/18/2008 5:37:46 AM GMT
I like the wheels.
Resourceful.
