LM2937 and LM2940 Trouble
Sooo I bout one LM2937 and two LM2940 from Parallax. Sadly just one of the three work. One LM2940 work but it is installed in to a B.O.E. I am guessing they other two are bad cause the circuit looks so simple. Unless the little metal tab has to touch ground too. That's the only thing different from the other two. I just put them into the breadboard. The tab on the one that is working isn't really touching ground any way. So I am lost and this has happen to me before! with others LM2940s before. So I am lost a little help please.
Thank, you
Thank, you
Using that output capacitor?·
Why so, the ones you are using are low dropout and use the output capacitor differently to manage low dropout.
How do you like my name change?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
