Can I power additional eeprom using Propeller IO pin?
william chan
Hey,
Can I use an IO pin on the Propeller to supply power to an additional 24LC512 eeprom? ( not the boot eeprom)
This way, I can totally switch off power and also prevent glitches from corrupting to the eeprom.
Will the voltage supply be high enough if the Propeller is run on 3.3v?
Is the pull-up transistor inside the Propeller a mosfet or bipolar?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
Be sure your SDA and SCL pullups connect to that pin as well and not to Vdd.
'Just a few PropSTICK Kit bare PCBs left!
