SPI driver on seperate cog
Hello i have written a simple SPI driver for interfacing a ISD1700 voice recorder chip.
The driver is writte in Spin because i dont need high data rates.
My problem is to get this driver working correctly on a sperate cog.
When i am using the driver from the main cog, everything workes fine -> so the driver generally works
So what i have to change to get the driver working on a seperate cog?
Andre
CON
baudRate = 10000
VAR
byte SPI_MISO
byte SPI_MOSI
byte SPI_CLK
byte SPI_CS
byte bitCount
byte byteCount
byte foo
word bitTime
PUB start :okay
init(20,17,18,19)
PUB init(MISO,MOSI,SCK,CS)
'read variables
SPI_MISO := MISO
SPI_MOSI := MOSI
SPI_CLK := SCK
SPI_CS := CS
'init port pins
DIRA[noparse][[/noparse]SPI_MOSI]~~ 'OUTPUT
DIRA[noparse][[/noparse]SPI_CLK]~~ 'OUTPUT
DIRA[noparse][[/noparse]SPI_CS]~~ 'OUTPUT
DIRA[noparse][[/noparse]SPI_MISO]~ 'INTPUT
OUTA[noparse][[/noparse]SPI_CLK]~~ 'set high
OUTA[noparse][[/noparse]SPI_CS]~~ 'set high
OUTA[noparse][[/noparse]SPI_MOSI]~ 'set_low
bitCount := 0
byteCount := 0
bitTime := clkfreq / baudRate
tx($01)
tx($00)
waitcnt(100000+cnt)
tx($65)
tx($C0)
tx($0C)
repeat while TRUE
PUB tx(dataByte) | t ,h ,rx
t := cnt
repeat h from 0 to 7
OUTA[noparse][[/noparse]SPI_MOSI] := dataByte & $01 'set MOSI pin
rx:=INA[noparse][[/noparse]SPI_MISO] << 7 | rx >>1
waitcnt(t += bitTime)
!OUTA[noparse][[/noparse]SPI_CLK]
dataByte:= dataByte >> 1
if h <7
return rx
Andre
The main thing that people forget is that each cog has its own I/O registers, so you need to execute the initialization routine in the new cog so the DIRA and OUTA registers get initialized properly. You could do "COGNEW(init(20,17,18,19),@stack)" in your start routine where stack is a minimum of 20 levels. In your init routine, the REPEAT loop would do the actual work after the initialization (and it can be just REPEAT).
There are examples of multicog programs in the Propeller Education Kit tutorials and in the "sticky" threads at the top of the thread list for this forum.
