USB port access same as serial port access from Visual Basic or C++
hi and thx for any help in advance- I'm using Visual Studio 2005 and a basic stamp 2
If I buy an usb adapter so I can use one of my newer computers that doesn't have rs-232 port.· Will I thru the usb adapter be able to do everything I now do with a RS232 serial port?
If I load the usb driver, can I use the serial port tool found in Visual Studio when programming in basic or C++ now?
This is all after I have already programmed the basic stamp.
I hope i've made myself clear?
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/catpageindex/2/ProductID/379/Default.aspx?txtSearch=usb+to+serial&SortField=ProductName%2cProductName
Jeff T.
That is important for programing BasicStamps, SXes, and Propellers. But it also comes in handy a serial port flow control can tell your PC to wait while a microcontroller is busy. Otherwise, your PC might send commands that are not being listened to by the microcontroller.
In other words, get the adapter that has all the goodies. You will need them.
How do you like my name change?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
