A/D W/O External Circuitry?
Is it possible to use the Propeller to measure an analog signal (voltage) without using an external chip? I'm using this sensor to measure some distances, and it outputs between 0 and 5 volts, with 2.5 volts the effective minimum. I'm guessing that I can use a resistor (4.7 kOhm?) just like any other five volt device, but what about getting useful distance information from it?
to jump to a spin method, but then I get confused about spin living in the hub, and assembly in the cog. Is it a viable modification to do this?
What appears to my non-assembly programmer eye to be the main loop:
:loop waitcnt asm_cnt,asm_cycles 'wait for next CNT value (timing is determinant after WAITCNT) mov asm_sample,phsa 'capture PHSA and get difference sub asm_sample,asm_old add asm_old,asm_sample wrlong asm_sample, par jmp #:loop 'wait for next sample periodI'm looking to use the same sensor as a backup to a maxbotix ultrasonic ranger. The curve for that sharp sensor is very flat as the distance ranges out beyond 3 metres. (perhaps 50 mv per meter) So i'll be interested to hear how the sigma delta goes. For my application I'm going straight to an external adc.
tubular
