usb to serial
hello,
some years ago , i bought a USB to serial adaptor via parallax. I also downloaded the drivers via the FTDI link on their website.
Now i want to buy a second adaptor. Can i use Two usb serial adaptor at the same time??
Greetings
Greetings
If you're using a Propeller (or an SX), you can transmit and/or receive on both serial ports at the same time.
If you're using a Stamp, you can only use one port (and one direction) at a time (a basic limitation of the Stamp).
You could transmit a message out one port, then transmit another message out the other port, then receive something.
