Midi music player (alpha)
Here's a very preliminary version of a MIDI player for the Prop!
Right, now it only plays level-0 MIDI's (with all notes in one track).
Most new files are not in this format, so probably need to be converted by a midi file editing tool.
Actually, I've only tested it with the single midi file included.· It may or may not play other files...
Update:· Wow, that first version was so riddled with bugs, I'm surprised it worked at all...· I'm attaching a version that can actually play two different songs...
Post Edited (Rayman) : 12/13/2008 1:54:37 AM GMT
Looks like I'm not the only one who has been bitten by the Propeller sound bug lately. [noparse]:)[/noparse]
Nice job! Looking forward to seeing this develop!
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Great idea. I'll try it over Xmas when I have time.
Aka: CosmicBob
Post Edited (Bob Lawrence (VE1RLL)) : 12/16/2008 12:40:49 AM GMT
(tick rate of around 1000 recommended)
They are some SIDs I converted to midi a while back.
@Ray: Any chance you could incorporate the ability to use .wav samples for instruments, like
I did with the wavetable/mellotron project? How are you generating the tones?
OBC
http://forums.parallax.com/showthread.php?p=769676
Basically, there is a wavetable for the attack phase, the beginning of the note.·
The end of the note is just a decaying sine wave created from an envelope table and a sine table.
Both are scaled in time to give the proper frequency.
I would be nice to find wavetables for different instruments, but I can't find any.
I suppose I could digitize my yamaha keyboard output and get it that way, but I don't really have any more time to spend on this project...
Overview:
This project was featured in the July 2008 issue of Everyday Practical Electronics magazine.
It was an off-shoot of the Easy-Chord which uses the same wave-table sound synthesis circuitry to produce instrument sounds controlled by a MIDI (Musical Instrument Digital Interface) input.
It can be used with MIDI keyboards, computers or just about any MIDI controller so is suitable for many DIY musical projects.
At the moment there are 18 instrument sounds, the same as on the Easy-Chord.
Nylon Guitar, Piano 1 , Organ 1
Steel Guitar, Piano 2, Organ 2
Electric Guitar, Elec.Piano 1, Organ 3
Fuzz Guitar, Elec.Piano 2, Strings
Synth Guitar, Harpsichord, Synth Strings
Banjo, Vibraphone, Trumpet
Website:
www.rainbowelectronics.co.uk/midi%20wsg.htm
Examples Wavefile:
www.rainbowelectronics.co.uk/instr-11-16-m.wav
Aka: CosmicBob
Post Edited (Bob Lawrence (VE1RLL)) : 12/13/2008 4:58:00 PM GMT
For an example see - Roland MT 90U
www.roland.com/products/en/MT-90U/index.html
Aka: CosmicBob
Xrocker Info:
home.nestor.minsk.by/game/news/2008/01/2804.html
Thanks! Ray.
Aka: CosmicBob
I am 85% complete with converting my 1928 Wurlitzer Theater Organ console to MIDI. (see attached image I hope!!!!! EDIT: ATTACHMENT DID NOT WORK I will try a 2nd time. Nope 2nd time did not work)
The Prop scans 485 inputs (keyboards, pedal board each with 1st and 2nd touch, stop tabs (above the keyboards) and also outputs control for·2 solenoids per stop tab (166). Inputs are read via a pair of 32 bit S/R with open collector output ICs and brought into the Prop 8 bits at a time. The entire console is scanned approx 100 x per second. The stop tab magnets are controlled by the same type ICs (8 of them, 4 for on and 4 for off)
The Prop sends out 2 sets of MIDI messages: 1 to a PC running a Virtual Theater Organ program (MidiTzer) and a 2nd to the pipe chamber where a second·Prop outputs to ~~ 1200 pipes and percussion discrete outputs. The same 32 S/R ICs are use to drive the pipe solenoids.
I will also be able to take a MIDI file and run the console from it and drive both the pipes and the virtual organ.
Once done I will be able to practice using just the PC program and also fire up the pipes and run both with the PC being able to add voices that I don't physically have in pipes.
I have also included a 25 level memory for the stop tabs which gives 25 complete settings for each piston (little white buttons under the keyboard).
The code is running well but needs clean up before it is ready for prime time.
Post Edited (Wurlitzer) : 1/5/2009 6:20:32 PM GMT
What is "32-bit S/R"?
I'm using a prop to interface two manuals and a pedalboard to a Mac running Hauptwerk.
If you like MIDI, check out my "sick day synthesizer" thread.
