Write/Read bits
Hello Forum,
i would like to ask if someone can guide me to write a program which can write 128x64 = 8192 bits to the memory and to read those bits 128 bits after another 128 and ect... 64 times .Is in the library something maybe similar?
which memory ?
HUB-RAM or EEPROM ?
128 bits is 4 longs
so read/write 4 longs and repeat this 64 times
As the propeller is a 32bit-CPU the only way to do this is to
make 128 Bits / 32Bits = 4 parts out of the 128 bits
storing each part in a long
could you write in DETAIL what you're trying to do with the whole project ?
I like to have an overview and with an overview I often find better solutions than just knowing one detail
Where and how are the bits coming in/out?
best regards
Stefan
