How to controll more than 8 reedrelays?
Hi.
I have completed a project that uses up to 8 read relays. I use the LPT port to controll the relays. This project works very good, with no problems.
I have now got another idea, and I need to controll 23 read relays for this project.
How can I do that, and what kind of interface should I use? (USE or COM)
one problem with a system like this, just for example, if you were to get a chip that could take all 8 inputs, then you would only be able to select 1 output at a time....
they make boards for this.. there are a couple companies that make them, you just plug it into an expansion slot and then get lots of outputs... but they are kinda pricy
what code/software are you using to output the "data" to the lpt?
almost sounds like your making a computer controlled Christmas light display....
depending on how fast you need your outputs to change, one other thought would be to serial shift out the data.. my thinking is something like this...
use pins 1-6 as the data lines, use pin 7 as a clock or shift, and then pin 8 as an enable.. if you shifted 8 bits, or clocks and then hit the enable that would give you 48 outputs. this system would be basically unlimited in the # of outputs, just daisy chain multiple shift registers on each data line, and then shift out that # of bits.. you could in theory have something like 32 bits or outputs on each pin 1-6 of the lpt port, and that would give you 192 outputs.. and you could select multiple ones to be on at a time, as long as the chips could drive that many relays simultaneously.
the more outputs with that system, the slower the update....
just a thought...
You could, however, use a ParallaxEFX DC-16 controller to control up to 16 relays, or two of them to control 32 relays, with a single serial-output signal (two wires, I think).· I have one of these but have never used it.· I think you can feed up to four of these, and control as many as 64 relays, with a single 2-pin serial output signal.· That may be enough to keep you busy.
You can do that with a Stamp -- which would serve to make this thread Stamp-related, as otherwise it is not.
· -- Carl, nn5i@arrl.net
Chris Savage
Parallax Engineering
