xbee module set up
i have just recently received a pair of xbee modules, and i dont know where to start. i would like to make some various sensors like the acceleromters from a wiimote be linked wirelessly to a propellor chip. i dont have any of the computer connect modules and i have no known way to update the firmware, what i want to do is to set it up so that each pin on the transmit senor module has the wireless connection with corresponding pins on the receiver prop module, any help is appreciated
http://www.selmaware.com/appbee/home.htm
Assuming you don't already have them, you'll want boards to put your XBees onto that can connect with your Propeller. These are nice ones at a good price.
Once you've mounted an XBee on one of these boards, your Propplug can be connected to it so you can use the XCTU software to change the XBee settings. It works beautifully.
The carrier boards from Selmaware will work great with either series. However major parts of the firmware are different from series 1 to series 2, and much of the program code you will find here applies to series 1.
Series 2 requires one of the modules to be a "coordinator", and that will most likely require that you re-flash the firmware for one of the modules. That was not necessary with series 1.
Tracy Allen
www.emesystems.com
i already have the following xbee, its the 60mw pro version, dont see a thing that says if i have version 1 or 2, how would i hook them up with the prop plug to flash them, and once is set up as a coordinator receiver pair, do i need a microcontroller to run the reciever, one thing i want to do is have a 3 axis accelerometer set up on various applications,
That's a regular version 1. For some cryptic reason, Sparkfun labels the version 2 XBees as "Series 2.5" (see the example lower on the page you linked us to - and notice that in the photo it's clearly marked "Series 2").
You change the settings by putting it onto one of the Selmaware boards with a four-pin header for your Propplug, feeding it power through the Vin and Vss pins (a 9v battery will do just fine), and running the Propplug from a USB port on your computer to the remaining four pins. Then you start up the XCTU software
www.digi.com/support/kbase/kbaseresultdetl.jsp?id=2125
and follow the instructions (RTFM first!).
Note that you can use an XBee (Series 1) to communicate as it is "out-of-the-box": you don't need to change any settings to use it in "transparent mode":
You could use it in that mode with a Stamp or Propeller on each end to format and transmit/receive the data. If your 3-axis accelerometer is one that puts out an analog voltage as signal (e.g., an ADXL3xx), you'll want to use the fancier settings and the ADC on the XBee. But if I were you, I'd get 'em working in transparent mode first before you go messing with all of that other stuff.
Post Edited (sylvie369) : 12/11/2008 11:38:13 PM GMT
You do probably need a breakout board of some sort, either from Selmaware or from Sparkfun. If you are using a propeller you do not need level translation to/from 5 volts, so the breakout board will mainly be an easy way to connect to the tiny pins (2mm spacing) of the XBee module.
Tracy Allen
www.emesystems.com
Tracy Allen
www.emesystems.com
