Botoxicated! Can a Propeller balance a wine glass for 4 weeks? - Now with Pres
Greetings!
I'm getting ready to install DanceBot into a public kiosk in the middle of Christchurch, NZ where it will balance a wine glass for 4 weeks.
I'm making slow progress to start selling this as a kit- let me know if you're interested... (Spin Debugger and ViewPort v4.1 are taking up a bunch of time, but are in last beta stages)
www.physicsroom.org.nz/kiosk/2008/montejo/
Hanno
Post Edited (Hanno) : 12/22/2008 11:56:11 PM GMT
Hanno
It is looking mighty spiffy, though. Yet, I dare say that if it merely stands in one place and doesn't move around, a lot of people might just think it's glued to whatever you have its tires setting on. And they might think, therefore, that it is not a quasi-living thing, containing a little bit of your ghost in its machine. Maybe you could have it drive around so that people can really see what it's doing.
Or consider this: you have a board floating in a trough of very viscous fluid, like silicone oil. It moves to one end of the board, where it dwells and senses how much tilt is taking place, and when the tilt gets to a critical point, it drives itself to the opposite side of the board and makes the board level out (for a while) until that side sinks down below a critical point, etc. If the fluid is a bit sticky, like glycerol or hot fudge, it might even get really funny to watch it running that chocolate fudge sundae from one side to the other, two giant outstretched plastic tongues poised at each end, trying their best to lick off the cherry on top, but alas the endless frustration and futility of it all....
Ah, such is life....
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
Neat idea!
...as far as "Can a Propeller balance·a wine glass for 4 weeks?" - I have no doubt that the Propeller could do it, however as it has been mentioned, the power required to manage·the unit for 4 weeks might be a difficult task.· That said, if the wheel diameter is increased so that you can move·the center of gravity "below" the wheel axis, it wouldn't require any power at all to balance the wine glass.· The only power required would be to move from one location to the next.· In this case under careful power management it could last 4 weeks but would depend on how often you wanted it to move.
Beau Schwabe
IC Layout Engineer
It might solve your problems, the stack of batteries will give you power for a long time and will make the bot unstable.
And the chocolate will taste good after 4 weeks if it work !
n45W73: One could still use a wine glass on top of the battery, but it may have to be taped down
- Bjarne Stroustrup
That said, I would just lower the CG, add some wires to make it look like a robot & call it a day. Since the display will be static anyway, it's not really like anyone will be able to tell. And you'll still get your message across. Looks pretty cool, though!
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
And, consider lighting the glass from the bottom for some drama.
--Rich
No- it will not balance the budget. However, it does work- at least in my office, with it's current dimensions as pictured. Very stable, with or without wine. It uses a camera to keep track of where it is relative to a "Southern Cross" on the floor (I'm in the southern hemisphere). It is an art project, but also feasibility study of the DanceBot hardware. It's powered by a thin, flexible cable connected to a battery that's trickle charged. I considered solar/inductive but the project is complicated enough. Interesting ideas about different colored fluids, seesaw, flywheel!
It's not a static display- it will dance.
Hanno
Hanno
Hanno
Going ok- had a problem with the wallwart transformer which blew out after 2 days, now replaced with a new one... Great attention getter- even in a busy city it attracts quite a few people...
I know you've been busy with the debugger and many other things, but when you have a chance could you update us on how the exhibit went? I see around Christmas there was trouble with the power supply. Once that was solved did your robot, manage to stay on its feet?
Just curious,
pgb
Thanks for asking! It was quite a challenge exhibiting a complex robot in a hot, public space. Did I mention that it was hot? On a few days the temperature outside the plexiglass greenhouse with halogen lights hit 35'C! I believe this caused an intermittent loose connection in one of the quadrature encoder connections. For a couple days we would find dancebot lying down looking quite sad with his champagne spilled on the floor- must have a had a rough night! (Since the encoder was only registering 1 part of the signal, the robot would get confused and finally run into a wall) Finally, I hooked up ViewPort's LSA to the bot and wiggled all the connections. It was easy to see that one of the traces fell out every now and then. Having found the fault it was easy to fix it. Now I know why they "bake test" electronic products. Other than that it went quite well, every time I checked on it there were a couple curious onlookers.
Hanno
