SX not working!!!!!
I have recently received an SX Tool Kit, and I am having problems with it. Basicily, I took it out of the box, installed the software, hooked up the SX equipment as shown, applied power and plugged it in to the computer; and·when I pressed "Verify"·a·window popped up saying "SX not found on COM1". I had no resinator in the socket, my power source was a 6 Volt battery pack pluged into the SX tech·board, the SX was correctly inserted into the socket, and the·USB·Plug·was inserted into each socket to test it(the preferences box gave me only one choice even though there were 2 sockets). I cannot have even had it long enough to break it!
If this is irregular, then this may·be it; whenever I plug in the SX Key to the USB cable, whether or not it is plugged into the proto board, the SX Key gets hot after a few seconds of being plugged into the USB Cable. I am using the cable that came with the kit. If you have ANY IDEA of what is causing this not to work, please give a suggestion!
Thank You For Reading! Please Respond!!!
I'd suggest you call Parallax Tech Support and let them assess it.
Bean.
"The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
www.iElectronicDesigns.com
Chris Savage
Parallax Engineering
You don't get to choose which ports are shown. The IDE scans your system for all available ports and then displays them. It's up to you to either figure out or know which port is which and plug into the right one. It won't hurt anything if you choose the wrong one, so it's not hard to get it worked out.
PeterM
If your system has a COM1 by default then that either is a built-in real Serial port (if it has an open DB-9 connector on the system) or it is in use by an Internal Modem.
COM6 is probably the USB to serial adapter. Does it disappear when you unplug the USB to serial adapter? Make sure the USB to Serial adapter is plugged in before launching the SX software on your system.
Another thing to check are other applications running on your PC. Does it have a lot of extra "Stuff" installed? Junk running in the background and in the system tray? Also, if you are running a virus scanner then check it's settings since some may block access to system ports.
Robert
1. Make sure that you have installed the most recent SX-Key IDE - it is version 3.2.92h BETA. You can download this version for free from the Parallax site in case you don't have it www.parallax.com/Portals/0/Downloads/sw/sx/Setup-SX-Key-Editor-v3.2.92h-BETA.exe.zip. At the end of the setup procedure, this version should install the required drivers for the FTDI USB to Serial converter automatically. If it does not, you also have the option to download and install it from the Parallax site (locate the "USB Driver Installer" link at the bottom of the home page www.parallax.com/Default.aspx?tabid=530.
2. After you have the driver and IDE installed, launch the IDE but do NOT connect the SX-Key USB to a USB port yet. In the IDE, open the Run/Configure dialog, and note which COM ports are listed in the "Serial Port" section. Shut down the IDE again.
3. Connect the SX-Key USB to any available USB port of your PC. Do not connect it to any passive USB hub you may have, as this may not be able to supply enough power to the SX-Key USB.
4. Launch the SX-Key IDE, and open the "Run/Configure" dialog again. Now, there should be one more COM port be listed in the "Serial Port" section. This is the one assigned to your SX-Key USB, so you should select this one.
Greetings from Germany,
G
First, disconnect the SX-Key USB. Next, check if the Windows device manager lists a USB to serial adapter (should be in the COM/LPT group). If any, remove it. Then install the FTDI drivers using the link I gave you in my last post. After the drivers have been installed, connect the SX-Key USB.
Good Luck!
G
