QT113 & Boe Bot...HELP
I'm trying to use the gripper, the QTI line follower, and the QT113 touch sensor all together with the boe bot.
I need the boe bot to follow the line, and pick up an object with the gripper. I want to use the touch sensor so that when it hits the object, the bot knows to engage the gripper. This is my problem. The data sheet and documentation for the QT113 is way too confusing. How can I make this work?
I just need to know how the QT113 sensor work, once i can get it to go on I and O, I can do the rest.
Chris Savage
Parallax Engineering
I also have 3 designs using Cypress PSoC Cy8C2143424. They work much better then the Qtouch parts, but require programming as it is an mcu. One of my Cypress 2 button boards has 7 total parts. The two major advantages are that the PSoC Cy8C2143424 is cheaper than the QT240 AND gives you much more versatility as an MCU.
~~ dRu ~~
I know the actual sensor goes between Vdd and Vss, but I dont know where the capacitors go or what to use to sense and where that goes. I'm completely new to robotics and electronics. The information that parallax gives is extremely confusing.
