Power supply?
I was wanting to replace the AA battery holder that comes with the BoeBot with a rechargeable 7.2V battery pack.·
··· I have·3 queations about this...
1. Is this safe to do (will it damage my robot)?
2. If safe, what amperage/mAh should i be looking for?
3. Where would i be able to find the barrel connection to wire it onto the battery pack (do i have to buy another AA battery holder and destroy it)?
If anyone knows something about this your·assistance would be greatly appreciated
Brandon
Brandon
2) Anything works, but the higher it is the longer your battery will be able to power the BOE
3) I made one using a Tamiya connector to attach to the battery, and a 9v battery clip from Radio shack to connect to the BOE.
Edit:· Ah!· That's right, 5.5 mm/2.1 mm.· That's the ticket.
Post Edited (allanlane5) : 12/8/2008 11:13:32 PM GMT
http://www.radioshack.com/product/index.jsp?productId=2103614
Jax
If a robot has a screw then it must be romoved and hacked into..
The BOE-Boost requires no wiring changes, as it tucks into the existing battery pack.
http://www.parallax.com/Store/Robots/RoboticAccessories/tabid/145/CategoryID/22/List/0/SortField/0/Level/a/ProductID/455/Default.aspx
Also, MSDTech, do you think that i would be better off with the Boe-Boost, as far as power longevity, compared to the power source ive mentioned above.
Again thanks,
Brandon
Jax
