Best Microcontroller for reading MIDI in
I have a new project I want to try that requires reading a MIDI stream. BS2 controllers·don't seem to be·a good fit. I have done a few projects with the BS2 controllers (BOEBOT and others) and I am comfortable with PBASIC. I have narrowed·down the selection for this project to either an SX or Javelin controller. I would prefer to stay with Basic or C as I have never gotten very far with Java, so my first inclination would be to use·the SX.
Do you have any pros/cons for either the SX or Javelin to read a MIDI in stream? If you have used either the SX or Javelin to read a MIDI stream then I would be interested to know if there were any hidden gotchas.
Thanks.
Thanks.
http://forums.parallax.com/showthread.php?p=533525
Go take a stroll through the Nuts/Volts articles posted on Parallax's website (here's one article: www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol6/col/nv122.pdf ).
I've gotten a basic circuit to read in the data, but didn't have the time to confirm what I was seeing (they were HEX characters....wasn't sure if they were correct MIDI status/commands).
I 'THINK' someone has done something with the Propellor (not sure) which would be a nice way to go! Have 1 cog do your midi reading/writing, and use other cogs to change lights or what have you!!
Cheers
(post how you make out!)
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
