SD Card interface: Can I read names of files already on card?
That would be nice. I've got a device hooked to a card that generates files with random names (unpredictable, really, unless I exactly synced an RTC with the internal clock of the other device...filenames include a timestamp down to the second). I need to be able to access these files with the propeller, but as far as I can tell, the SD card object requires a known filename to be specified.
Is there a way around this?
Rafael
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
Rafael
You can't win.
I'm not sure why you would want to name files randomly, unless, of course, you have time stamps recorded inside the files along with whatever data you record. You might what to elaborate more on what you're trying to do both on the data recording end of it and on the data accessing end of it.
Rafael
You can't win.
2) There are PUB routines in the SD card object called "opendir" and "nextfile" used to make directory listings. You could use these to either go through all the root files in directory order looking for one that matches some criteria that you specify, then open the file using its name. You'd have to go through the file list each time unless you want to save the names in an array to speed up the process next time.
re-inventing the wheel.
http://forums.parallax.com/showthread.php?p=719452
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
here's the relevant code from Femto...
146: ' FILES if \fsrw.mount(spiDO,spiClk,spiDI,spiCS) abort string("Can't mount SD card") fsrw.opendir b := 0 d := false repeat while fsrw.nextfile(@f0) == 0 d := true if b == 39 dsp.out(dsp#Cr) b := 0 dsp.str(@f0) repeat 13 - strsize(@f0) dsp.out(" ") b := b + 13 if d dsp.out(dsp#Cr) \fsrw.unmount
