PIR firing on a cycle
I got a PIR today and set it up on a loop in Spin, nothing else running, with a beep if high. The unit seems to work in terms of detecting motion, but it also has a cycle of a very rhythm of on/off with no apparent trigger:
2 seconds on
2 seconds off
I set it to the Normal mode and it is basically the same issue. The unit is in a room by itself and I am in another room.
There is nothing obvious (that I am aware of) firing an infrared pattern in the room or nearby.
I put it in a card board tube and it stopped in less than a minute. 3v3 in, high out is 2.8 with no load.
Any suggestions?
Post Edited (TChapman) : 12/4/2008 4:19:53 AM GMT
2 seconds on
2 seconds off
Any suggestions?
Are there any fluorescent lamps nearby?
Are there any dimmers in that room?
How is that room heated?
Is there a wall clock in that room?
If this was tested in a house, which room was it in?
So many questions, so few answers
Bruce Bates
When all else fails, try inserting a new battery.
No dimmers.
At present there is is no air conditioning on, 74F.
Only a small LCD clock on a table.
In a vocal booth, concrete floor, treatment on all walls and ceiling, 4 x 6 glass in the wall.
When I put it in a cardboard tube and stuff a paper towel in the end that is exposed it will stop triggering.
I am thinking it is defective due to the output being lower, but I am open to any experiments to test it.
Does the touch pad have a model number on it?
Can you tell which Qprox sensor is being used?
NOTE: Just for the record, Atmel and Qprox appear to be partners.
Bruce Bates
This is one of those mystery issues, I solved it, but makes no sense. There is a remote PCB that has a PCF8574 on it, plus a QT1081 with 4 outputs into 4 inputs on the 8574, and 4 inputs to the 8574 from a terminal block to allow whatever inputs you want to give it. I was testing the PIR into one of the inputs to the 8574, reading it with I2C, and getting the false triggers from the PIR.
At first I thought it was proximity to the QT1081 that was causing it, but in fact when I pull the PIR output off the terminal block, it stops false triggering regardless how close I hold the unit to the PCB. It constantly false triggers if the output is connected to the 8574 along with the 4 Qt1081 outputs.
Seems to work fine when connected straight to a Propeller input, even in close proximity to the Qprox chip and PCB.
As an interesting test, I put a cardboard paper towel center around it, and pulled the PIR back into the cardboard tube so the Fresnel lens was maybe 4" from the outside edge. This created a circular "detectable" pattern of around 12" at 4' feet away. I suppose with a smaller tube plus pushing the unit deeper a tighter pattern could be created.
Very cool device.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
If it were RF, would it misfire due to something on it's output?
Using the same power, if I connect the outut of the PIR to the terminal block, it misfires in a repeat loop. If I connect to a Propeller pin directly, it is fine.
Below is the board and schematic. The last 4 inputs on the terminal block connect to 4 10k trim pots to serve as voltage dividers in case there are devices above 3v3 connected.
The PCF8574 has 4 outputs from the Qprox QT1081 to pins 1-4, then the 5-8 inputs are for misc sensor devices. The 4 Qprox inputs go to terminal block inputs 1-4, so they can be connected to remote sensors if desired.
Marty
Lunch cures all problems! have you had lunch?
Another trace that looks shaky is the ground connection between the PCF8754's bypass capacitor and the IC's ground. This connection loops around most of the board and the Q-touch chip adding a significant parasitic inductor in series with the bypass capacitor.
I still don't see where the PIR is connected to ground on this system. What connector on this board is the PIR's ground connected to? When the PIR is directly connected to the Propeller is the ground connection of the PIR still connected to the board with the Q-touch sensor or is the PIR's ground connection also moved to directly connect to the Propeller board? Primarily I'm assuming that the previous poster who said PIR sensor's are sensitive to RF is right, and seeing what has been done to isolate a RF source (the Q-touch circuit) from the PIR sensor.
My two cents,
Marty
P.S. The datasheet for the q-touch sensor mentions a calibration test that occurs every two seconds. This is likely the specific culprit.
Post Edited (Lawson) : 12/5/2008 10:22:28 PM GMT
The anomaly only occurs when using 3v3 to the PIR, but 5v is fine.
It appears it is may be some type of loop, maybe a strange ground loop or something I can't explain, but the boards are common ground, and I even jumpered the grounds on the boards and PIR to be sure.
When you boot up, it doesn't misfire until you manually trigger it once, then it triggers about every 5 seconds forever when using 3v3 on the PIR. There is nothing obvious on the scope on the power to any of the boards, PIR, 8574, or output lines on the PIR, even at high res the scope meters negligible noise on the PIR. Putting the PIR in a closed box still produces the misfire.
I can just as easily run it to a 5v connector, so there is no real reason now to try to understand the strange circumstances with 3v3.
Leon
