Sawtooth Ramp Using Counter? — Parallax Forums
T ChapT Chap Posts: 4,224
edited 2008-11-30 03:38 in Propeller 1
Thinking out loud, trying to determine the most efficient method to do this:
Is there a trick to get a counter and pin to output this type of ramp with adjustable time period(T)... without using software, using counter only? The AN001 shows assembly oversight in all examples to generate waveforms.
The plan is to use the ramp to trip a comparator wherever when it hits the level of an external DC (dynamic) voltage. When it trips, an input stores the iTrip voltage as one of 1024 or 2056 samples in an array. The array is "learned during a "LEARN" method. The array gets stored in eeprom for future recall after boot. On every other subsequent run, the values of the sample get sent back to the comparator with a slight offset upwards (RunOffset) so that theoretically the comparator stays tripped under normal circumstances, and stays low if the analog input is greater. If there is an upwards deviation of > RunOffset, there is a fault.
Not actual code, just ideas:
CON tripPin = 0  'input pin monitoring comparator
VAR  long SampleRef[noparse][[/noparse] 1024], Offset, iTripValue
       word  SampleIndex
PUB Main        'over simplified
    repeat 1024
     LearniTrip(SampleIndex)
     SampleIndex++
PUB LearniTrip(x)
        'waitpeq  tripPin to = 0, meaning wave form ramp has exceeded analog input
        SampleRef[noparse][[/noparse]x] := iTripValue    'get value of most recent iTrip val(voltage the sawtooth was at when tripped comp)
        return SampleRef[noparse][[/noparse]x]
PUB GenerateSawtooh
      'preferably some counter only process to create fixed T waveform
PUB WriteSampleToEeeprom
     'write SampleRef  array to eeprom
PUB GetSampleFromEwprom
   'get the array back from eeprom on each boot
PUB CompareiTrip
      if GetTripPinState == tripped   'compare stored value to actual new value
         'do something
PUB SetOffset
       Offset := 5   'arbitrary number
PUB GetTripPinState
      if tripPin == 0
       return tripped
    else
      return untripped
Post Edited (TChapman) : 11/29/2008 9:46:37 PM GMT
    edited 2008-11-29 22:03
    The ramp would have to be mediated by code. This is done by gradually increasing FRQx in a DUTY-mode counter.
    With an external op-amp integrator, however, you could use FRQx to set the slope of the ramp, which would be a fixed value; then use an analog switch to discharge the integration cap, thus starting a new ramp.
    'Just a few PropSTICK Kit bare PCBs left!
  • T ChapT Chap Posts: 4,224
    edited 2008-11-29 22:32
    Thanks Phil, I assumed it wasn't possible, but thought maybe some of you guys had some counter tricks to get around using a cog to do it. Your other idea is interesting, I will explore an external idea like that.
    edited 2008-11-30 00:19
    Here is an idea using PLL Video mode to generate a rising value at FRQa X:
    ctra :=    '  duty mode @ itrip pin
    frqa := 0
    ctrb := %00001 << 26   'does not use any pins in this mode
    frqb := 100
    This generates a number from -2b to 2b in a loop.
    I have an existing repeat loop doing other things that I can drop the Read iTrip Pin inside to always monitor the comparator. This way, it uses no extra dedicated loops, cogs, etc.
    ex.
    EDIT .
    Dira[noparse][[/noparse]pin] := 2
    ctra := %00001  'this ramps at any desired speed(set at frq)   from -2b to 2b, no pins used in PLL
    frqa := 1  'very slow ramp
    ctrb := %00010
    frqb := 0
    repeat
       'frqb := frqa
      'some code to translate the PLL -2b to +2b ramp into voltage 0 - 3v3
    Any suggestions?
    Post Edited (TChapman) : 11/30/2008 1:43:46 AM GMT
    This may be common knowledge, but I find this interesting that I can set any fixed voltage using a counter only show below.
    So, using 2 counters I am sure there is a way to generate a sawtooth at any fixed ramp time(based on the speed of the loop used modifying PHSb).
    Counter 1 is the PLL %00001 mode, incrementing at 1, it does not use a in. It counts (at least on my LCD) from -2b to 2b, then repeats.
    Counter 2 is %00100, and outputs to a pin iTrip.
    If I can somehow do some math to convert PHSa -2b - 2b into the correct numbers shown, I can generate the waveform needed with no code:
    Here are the fixed voltages I get from counter B using a 10K resistor and .01 filter cap both meter and scope:
    Set pin to out, %00100
    FRQb := 5000
    Repeat
       PHSb := y
    if Y = the following, the respective voltage appears at pin:
    Substitute for y
    -1000 .08vdc
    -25000 .09
    -50000 .10
    -100000 .13
    -200000 .17
    -300000 .22
    -400000 .265
    -500000 .310
    -600000 .355
    -700000 .4
    -800000 .446
    -900000 .491
    -1000000 .536
    -1500000 .761
    -2000000 .98
    -2500000 1.21
    -3000000 1.437
    -3500000 1.662
    -4000000 1.88
    -4500000 2.11
    -5000000 2.33
    -5500000 2.56
    -6000000 2.78
    -6500000 3.01
    -7000000 3.22
    -7500000 3.22 same
    -8000000 3.33
    Just some minor non linear issues, but adequate for the task.
    Can anyone think of a formula to convert the PHSa values -2b - 2b into a range of -1000 to -8_000_000 respectively?
    Thanks for any ideas!
    Nice reverse sawtooth wave:
    FRQb := 5000
    repeat
      y := -1000
      repeat while y > -8_000_000
         phsb := y
         y := -1000
    Post Edited (TChapman) : 11/30/2008 4:30:34 AM GMT
