IR Control Instruction Sheet
Oldbitcollector (Jeff)
Here's a novel idea for the Parallax IR remote page.
How about scanning the Instruction sheet. [noparse]:)[/noparse]
If someone has a copy of it and doesn't mind scanning it, I'd appreciate it.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
OBC
OBC
I couldn't find my code list either.
But in a rare moment of genius I put a label on the bottom that says "Sony = 605".
Sony is the code that is needed to work with the Parallax software, so if that is what you want use code "605".
Bean.
"The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
www.iElectronicDesigns.com
to reprogram it for a quick volume adjustment on my daughters set.
Sooner or later a "standard" will emerge for universal remotes.. Just not today. [noparse]:)[/noparse]
OBC
