Lookup / Lookdown
hmlittle59
Hello all,
I have NO variable space left....with that said, I've learn to use "Lookup" (Lookup index,[noparse][[/noparse]clock,qtyofdr,..etc.) and I was able to store some "Auto-Config." values in the DS1302 ram. Appears to work great. Loop through Next ram byte location to store value, at the same time looping through LOOKUP to get the value to store... Now, Does LookDown work the same way but in reverse? Meaning get a value from my RAM location (DS1302) and it will be assigned to the respected (LookDown index,[noparse][[/noparse]clock,qtyofdr,...etc.) location while looping through?
My BOE_BOT book only has Lookup examples and I can't find much on the Forum.
1) I can save "CONFIG" values to DS1302 Ram.
2) How do I get them back without ARRAY() space
3) Does Lookdown save values within the Brackets that have variable names in it [noparse][[/noparse]clock,qtyofdr,...etc.)
I HAVE LEARN SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
hmlittle59
Have you looked in the IDE Help File, or downloaded the PBASIC Manual? Both of those resources should show you how to use ALL the PBASIC commands, as well as showing some brief examples.
Bruce Bates
When all else fails, try inserting a new battery.
thanks.
hmlittle59
