asm coginit
I'm some what new to prop asm and am trying to convert a spin program a wrote to asm.· Everything is working when i start all the cogs in spin but i can't seem to figure out how to get a cog to start in asm.· If anyone has an example of this it would be greatly apreciated.· I am starting each cog with a given id so i don't need to get the id of the started cog back.
Thanks in advance.
Thanks in advance.
If you're starting an assembly cog from Spin, use the COGNEW statement. There's an example on page 191 of the Propeller Manual.
If you're starting an assembly cog from assembly, use the COGINIT instruction with the NEW bit set in the operand (page 366).
sorry if this is a bit long winded and/or confusing I will post my code once I get back and clean it up a bit.
(changed to shifting by 14 and 2 bits but still no luck)
Post Edited (Delus) : 11/27/2008 6:47:14 PM GMT
resetcog cogstop cognr mov t1,cogpar 'restart cog shl t1,#14 or t1,cogaddr shl t1,#2 or t1,cognr coginit t1cognr, cogaddr and cogpar are registers which saves the id, the startaddress and the parameter value to pass to the new cog.
cogaddr and cogpar must have the lower 2 bits cleared (long aligned addresses).
Andy
here's the code:
var
long waitTime
pub main
waitTime := 5_000_000
coginit(0, @mainEntry, @waittime)
'blinkTest
pri blinkTest
dira[noparse][[/noparse]12] := 1
repeat
if outa[noparse][[/noparse]12] == 0
outa[noparse][[/noparse]12] := 1
else
outa[noparse][[/noparse]12] := 0
waitcnt(5_000_000+cnt)
dat
org
mainEntry
mov parameter, par
mov cID, #1
mov cInitDest, #0
and parameter, Mask14Bit
shl Parameter, #14
or cInitDest, parameter
and BlinkEnt, Mask14Bit
shl BlinkEnt, #2
or cInitDest, BlinkEnt
or cInitDest, cID
coginit cInitDest
cInitDest res 1
parameter res 1
cID res 1
BlinkEnt long @blinkTestEntry
Mask14Bit long $00_00_FF_FC
org
blinkTestEntry
mov outpin, #1
shl outpin, #12
mov dira, outpin
rdlong delta, par
mov wait, cnt
add wait, delta
blinkLoop xor outa, outpin
waitcnt wait, delta
jmp #blinkLoop
outpin res 1
delta res 1
wait res 1
this seems to work for a few minutes then the led attached to pin 16 stops blinking and stays lit all the time.(actually after running it a few times it just stops blinking lit or unlit seems random)
ps how do you post code in a box as above?
Post Edited (Delus) : 11/27/2008 7:10:33 PM GMT
this is solved at compile time and gives not the right address for blinkTestEntry (only an object relativ offset)
You can add this to the Spin main routine, before the coginit:
BlinkEnt := @blinkTestEntry
then you have the right address in the BlinkEnt var when the cog is started.
Andy
Instead of
use
here's my current code
[noparse][[/noparse]code]
var
long waitTime
pub main
· waitTime := 5_000_000
· coginit(0, @mainEntry, @waittime)
· 'blinkTest
dat
······· org
mainEntry
······················· mov······ parameter, par
······················· mov······ cID, #1
······················· cogstop cID
······················· mov···· t1, #0
······················· mov···· t1,parameter·············· 'restart cog
······················· shl···· t1,#14
······················· or····· t1,BlinkEnt
······················· shl···· t1,#2
······················· or····· t1,cID
······················· coginit t1
······················· mov······ cID, #0
······················· cogstop·· cID
············· mov······ cInitDest, #0
············· 'and······ parameter, Mask14Bit
············· shl······ Parameter, #14
············· or······· cInitDest, parameter
············· 'and······ BlinkEnt, Mask14Bit
············· shl······ BlinkEnt, #2
············· or······· cInitDest, BlinkEnt
············· or······· cInitDest, cID
············· coginit·· cInitDest
BlinkEnt····· long····· @blinkTestEntry
Mask14Bit···· long····· $00_00_FF_FC
t1··········· res 1···········
cInitDest···· res 1
parameter···· res 1···················
cID·········· res 1····································
············· org
blinkTestEntry
············· mov······ outpin, #1
············· shl······ outpin, #12
············· mov······ dira, outpin
············· mov······ wait, cnt
············· add······ wait, delta
blinkLoop···· xor······ outa, outpin
············· waitcnt·· wait, delta
············· jmp······ #blinkLoop
delta········ long····· 5_000_000
outpin······· res 1·············
wait········· res 1
[noparse][[/noparse]/code]
Post Edited (Delus) : 11/27/2008 10:52:09 PM GMT
and i can't get the code box to work on this form arg!
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB Main {Launch cog to toggle P16 endlessly} cognew(@mainEntry, 0) 'Launch new cog DAT {Toggle P16} ORG 0 'Begin at Cog RAM addr 0 Toggle mov dira, Pin 'Set Pin to output mov Time, cnt 'Calculate delay time add Time, #9 'Set minimum delay here :loop waitcnt Time, Delay 'Wait xor outa, Pin 'Toggle Pin jmp #:loop 'Loop endlessly Pin long |< 12 'Pin number Delay long 30_000_000 'Clock cycles to delay Time res 1 'System Counter Workspace ORG 0 mainEntry cogstop cognr mov t1,cogpar 'restart cog shl t1,#14 or t1,cogaddr shl t1,#2 or t1,cognr coginit t1 cogpar long 0 cogaddr long @Toggle cognr long 1 t1 res 11. Remove the cogstop instruction. As you stop #1 you're usually stopping yourself (spin starts on #0, so cognew will most likely run mainEntry in #1).
2. The current compiler miscalculates function addresses, use @Toggle + $10 instead.
3. If you want to toggle pin 16 use |< 16 not |< 12
4. Get used to not using absolute cog IDs [noparse]:)[/noparse]
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB Main {Launch cog to toggle P16 endlessly} cogaddr := @Toggle cognew(@mainEntry, 0) 'Launch new cog DAT {Toggle P16} ORG 0 'Begin at Cog RAM addr 0 Toggle mov dira, Pin 'Set Pin to output mov Time, cnt 'Calculate delay time add Time, Delay :loop waitcnt Time, Delay 'Wait xor outa, Pin 'Toggle Pin jmp #:loop 'Loop endlessly Pin long |< 16 'Pin number Delay long 30_000_000 'Clock cycles to delay Time res 1 'System Counter Workspace ORG 0 mainEntry mov t1,cogpar 'restart cog shl t1,#14 or t1,cogaddr shl t1,#2 or t1,cognr coginit t1 cogpar long 0 cogaddr long 0-0 cognr long 1 t1 res 1Andy
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB Main {Launch cogs to toggle P16 and 17 endlessly} cogaddr := @Toggle cogaddr2 := @Toggle2 coginit(2,@mainEntry,0) 'Launch new cog DAT {Toggle P16} ORG 0 'Begin at Cog RAM addr 0 Toggle mov dira, Pin 'Set Pin to output mov Time, cnt 'Calculate delay time add Time, Delay :loop waitcnt Time, Delay 'Wait xor outa, Pin 'Toggle Pin jmp #:loop 'Loop endlessly Pin long |< 16 'Pin number Delay long 30_000_000 'Clock cycles to delay Time res 1 'System Counter Workspace {Toggle P17} ORG 0 Toggle2 mov dira, Pin2 'Set Pin to output mov Time2, cnt 'Calculate delay time add Time2, Delay2 :loop2 waitcnt Time2, Delay2 'Wait xor outa, Pin2 'Toggle Pin jmp #:loop2 'Loop endlessly Pin2 long |< 17 'Pin number Delay2 long 15_000_000 'Clock cycles to delay Time2 res 1 'System Counter Workspace ORG 0 mainEntry mov t1,cogpar 'restart cog shl t1,#14 or t1,cogaddr shl t1,#2 or t1,cognr coginit t1 mov t1,cogpar2 'restart cog shl t1,#14 or t1,cogaddr2 shl t1,#2 or t1,cognr2 coginit t1 cogpar long 0 cogaddr long 0-0 cognr long 2 cogpar2 long 0 cogaddr2 long 0-0 cognr2 long 3 t1 res 1only works for
and
coginit(3,@mainEntry,0) 'Launch new cog
i understand that 2 will restart the cog which launches the other cogs and thus only blinks one led but why do 0, 1, and 3-7 not work?
yes i know it's best practice to let the prop choose which cog to start but this is a curious outcome
Post Edited (Delus) : 12/21/2008 6:54:31 AM GMT
Why are you so keen about using cogINIT instead of cogNEW ?
all eight cogs are EXACTLY the same. So it does't matter which cog you use for what.
As Mike already mentioned it's more buggy to use coginit than cognew
best regards
Stefan
Well, bit 3 (%1000) makes all the difference. If set coginit becomes cognew (see prop manual p.366).
