DLP-TXRX-G with propeller
Hello, I just recently got a DLP-TXRX-G for free and was hoping to make it work with my Propeller but I am having problems.· I'm thinking it has to do with the DLP's DTR, pin 4. Here is the DLP's datasheet (it kinda sucks) URL http://www.dlpdesign.com/usb/dlptxrx-v14-ds.pdf·. I was wondering if anybody has any experience with these or can help in anyway. Thanks.
Are you planning to connect to a protoboard? or a Propeller on a solderless Breadboard?
If connecting directly to a DIP Propeller
> Propeller pin 40 (P31)
> Propeller Pin 39 (P30)
> VSS on breadboard (pins 9 and 29 on Propeller)
> Propeller pin 11 (reset)
This *should* work - I don't see a cap in the DTR circuit to stretch the DTR pulse, but I think it will work as is.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Tx, Rx, GND, Reset, Vcc
It's not the same pinout as that PropPlug, but the signals are there and it appears to use the same FTDI chip, so the drivers installed with the Propeller Tool should work. It also provides either 5V or 3V, selectable with a "solder bridge"
Duffer
It certainly wouldn't hurt anything to try
I just refered to the PropPlug schematic, I don't see the 10k resistor to VSS that you are refering to. On the DLP design, I see now that there is a 10K resistor between the FTDI chip and the base of the transistor. whereas the Parallax design pulls this low with a 33K resistor. This may be the difference in circuits that is causing the propeller not to get the proper reset pulse, and thus not entering programming mode.
Brian
That resistor is there to pull that section of the circuit low when the DTR signal is not actively driven. I'm not sure why the DLP design omits it. I can't think of a good way to add that to their circuit board either
Thank you! I hate to follow a compliment with a admonishment, but vulgarity is normally frowned upon in these forums.
Brian
