Using the SX28 Socket on the BS Professional Development Board
I'm working on some rather complex projects and breadboard space on the PDB is running out. Looking at the schematics for the PDB it appears there is an easy way to extend the I/O on the board by inserting a 74165 in the lower portion of the SX-28 socket. As long as you not using the 40 pin BS, this is an easy way to expand the inputs for infrequently read devices like the DIP switches. A similar trick could be used with the 74595 too. A neat way to pick up 8 more IO pins on the PBD without going to a BSp40 and not using up any breadboard space.
This is a neat idea, very creative.
· -- Carl, nn5i@arrl.net
