Games which scroll in both X and Y directions.
Are there any Hydra games which use tile scrolling in both X and Y direction and allow the player to freely roam around the game map?· I looked at the Master Project List sticky but not all games are there, me thinks, and not all those listed had screen shots or videos.· (I do not have a Hydra.)
Post Edited (Lord Steve) : 11/25/2008 5:39:06 PM GMT
Bet a cool version of this could be done using the driver Alex and I are playing with..
Someone should do a Gauntlet clone..
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
You're AI_Driver would be great for that, and since characters and baddies can't overlap each other anyway [noparse]:)[/noparse] so that would be ideal for the game [noparse]:)[/noparse]
Funny that you mention Gauntlet... I have been working on it, but got side-tracked [noparse];)[/noparse] If anyone though wants to give it a try in the mean time though feel free. The current proejct is a sort of "test bed" for some of the things I am trying to figure out.
@Lord Steve:
As far as "scrolling x y" (meaning horizontal and vertical scrolling), Underwelt is another that uses a form of block·scrolling, and Ailen Invaders (with the Hydra book) also implements smooth vertical scrolling. Progue (a rogue-clone) might...but I am not sure. I know a lot of "rogue-like" games use a basic form of scrolling (or "windowing") [noparse][[/noparse]Edit:] And if you plan on getting a PropGFX, I think Baggers has an 8-directional scrolling routine.
As long as you implemented a 2-dimensional array, and knew where the "top left" corner of the display is, you can do a "fake" sort of horizontal/vertical scrolling.
Example: (map where # = block, _ = open space)
1 2 3 4 5 6 7 8 9 0
1# # # # # # # # # #
2# _ _ _ _ _ _ # # # #
3#_ _ _ _ _ _ # # # #
4# # _ # # # # # # #
5# # _ # # # # # # #
Now, imagine that your "window" (meaning what you can see on the screen is a simple 2x2 space. If the top-left was at x1 y1, you would be able to see:
1 2
1# #
2 # _
if you moved right 1 space (inrementing the top-left to x2, y1 you would see:
2 3
1# #
2_ _
Well, either you get the idea, or I have confused you horribly and I apologize.
Post Edited (trodoss) : 11/26/2008 6:55:04 AM GMT
You don't happen to already have the scroll code for displaying the "windowed" area already done do you?
I'd love to see it for learning if you do.
I'm picturing a DAT section that looks something like this.
I suppose that the code would "center" the hero sprite in the middle of the
windowed area moving the board and other characters as required. I can *almost*
picture the code for this, but haven't wrapped my head around DAT usage yet.
(Time to study.. [noparse]:)[/noparse] )
OBC
OBC
Andre'
In your CON section, you might have something like:
In your DAT section you would have map data defined:
DAT Level_Map byte 1, 1, 1, 1, 1, 1, 1, 1, 1, 1 ,1, 1, 1, 1, 1, 1, 1, 1, 1, 1 ,1, 1, 1, 1, 1, 1, 1, 1, 1, 1 byte 1, 0, 0, 0, 0, 1, 1, 1, 1, 1 ,1, 1, 1, 1, 1, 1, 1, 1, 1, 1 ,1, 1, 1, 1, 1, 1, 1, 1, 1, 1 byte 1, 0, 0, 0, 0, 0, 1, 1, 1, 1 ,1, 1, 1, 1, 1, 1, 1, 1, 1, 1 ,1, 1, 1, 1, 1, 1, 1, 1, 1, 1 byte 1, 1, 1, 1, 1, 0, 0, 0, 0, 0 ,0, 0, 0, 0, 0, 0, 0, 1, 1, 1 ,1, 1, 1, 1, 1, 1, 1, 1, 1, 1...you get the idea
Then you might have something like the following:
'current_x and current_y represent the 'top left' of the viewable area PUB DrawMapWindow (current_x, current_y) | map_x, map_y, map_char repeat x from 0 to DISPLAY_WINDOW_WIDTH repeat y from 0 to DISPLAY_WINDOW_HEIGHT map_x := current_x + x map_y := current_y + y 'you would have to add 'bounds checking' map_char := byte[noparse][[/noparse]@Level_Map][noparse][[/noparse]map_x * map_y] 'pokechar used for an example text.pokechar (x, y, blue, map_char)[noparse][[/noparse]Edit:] When accessing the data in this example, I am taking advantage that the data is structured in 30 rows by 30 columns (using multiplication the way you would 'fake' a 2 dimensional array in Spin).
...from there you would just add your 'character' on top of the display.· When you add bounds checking to this (meaning when the displayable window could not croll, that would be when the character would 'move' around the screen.· Otherwise, as you mentioned, the character would effectively be 'centered' on the displayable area, and you would calculate what is the top left corner of the window at all times.
Hopefully that is enough to get you started.· I haven't tested the above code, but it should at least help point you in the right direction.· Bear in mind this is only one of what could be any number of implementations to do the same thing.· Definately do some expiramenting on your own.·
Again, if the example is as clear as mud, I apologize in advance.
Just to clarify --·this is more an example of how to handle map movement rather than real scrolling.· As Baggers and Andre have mentioned, there is a lot more that goes into 'pixel perfect' scrolling.· If you get interested in that there is certianly going to be good information in the Hydra book, and also as Andre mentioned, an example of a vertical scrolling game on the CD.· For some games (and some people) the 'windowed' map movement is good enough.· It most likely isn't going to yield 'Final Fantasy' -- more like maybe Rogue, or some of the very first RPG's.
Post Edited (trodoss) : 11/26/2008 2:20:59 PM GMT
Without sprites, you don't need to have a scanline buffer at all, even with horizontal scrolling. You just need to keep two tile lines in COG memory all the time, and you can shift them left or right as needed. Horizontal scrolling is accomplished through setting where on the first tile you're starting then keeping a running count of the number of scanlines in the video frame.
Additionally, I know there are a few more drivers out there that do smooth scrolling. Off of the top of my head, I know the XVIDEO driver does it with sprites (if you've got a RAM expansion card) as well as Bamse's multi-cog renderer.
Post Edited (Spork Frog) : 11/26/2008 5:21:18 PM GMT
