Serial Data 'pass-through' — Parallax Forums
DarrenYDarrenY Posts: 61
edited 2008-11-27 04:49 in Propeller 1
If I wanted to merely 'pass-through' GPS NMEA data through the prop could I just set one pin as an input and another as an output and merely just make output := input?
Is there something I am missing?
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2008-08-09 12:45
    I'm not sure why you want to·but this should work
    repeat
      outa[noparse][[/noparse]pinx]:=ina[noparse][[/noparse]piny]
  • DarrenYDarrenY Posts: 61
    edited 2008-08-09 13:04
    My Prop is connected to my GPS but I want to pass through the NMEA data to a uM-FPU V3.1 to do the NMEA decoding, thus offloading the prop.
  • hippyhippy Posts: 1,981
    edited 2008-08-09 13:49
    Although the uM-FPU V3.1 has some support for processing NMEA strings it requires an SPI or I2C interface so, assuming your NMEA data arrives as serial, you'll need to process and convert that, send it to the uM-FPU and read results back. That's not 'pass-through' as I'd expect most programmers to understand it.
    You could possibly use the SERIN and SEROUT commands of the uM-FPU to interface with the NMEA device ( direct or through the Propeller ) but I think you need to explain exactly what you are trying to do and want in a little more detail.
  • Capn_DaveCapn_Dave Posts: 20
    edited 2008-08-11 04:44
    Remember there is processing time involved in performing the repeat, the in and the out instructions.
    So this may only work for slow signals. I beleive the outputs are updated via the hub which is clocked every 8 clock cycles.
    You may have better luck using the CNTA or CNTB hardware.
    See AN001 - Propeller Counters· on this page http://www.parallax.com/tabid/442/Default.aspx
    Caught in the PropWash
  • Ken PetersonKen Peterson Posts: 806
    edited 2008-08-11 15:58
    I had a case on a propeller project where I needed to invert a signal. Instead of using a separate chip for one inverter, I just used a couple of pins on the Prop and a counter. I used mode %10101 (logic !A). The B pin was the inverted A pin signal delayed by one clock cycle.
    ·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
    - Bjarne Stroustrup
  • shanghai_foolshanghai_fool Posts: 149
    edited 2008-11-23 04:01
    There is a driver object for the uFPU v3.1 in obex http://obex.parallax.com/objects/286/
    It has most of what you need to communicate with the FPU. I am currently trying to expand the driver for GPS related commands. Any help appreciated.
    edited 2008-11-23 14:01
    I cannot find the author of the program (I.K
  • pgbpsupgbpsu Posts: 460
    edited 2008-11-23 19:58
    shanghai_fool-
    I'm not sure this is what you're looking for, but here's a snippet I used to verify that I was getting good data from my GPS. I used the GPS_IO object (by Perry) with some modification. After starting that object:
    I used the following code to just pass what was coming into the prop from the GPS to the Prop Serial Term where I could see what it was doing:
    OBJ
    gps : "GPS_IO" 'no COG required
    uarts : "pcFullDuplexSerial4FC" '1 COG for 3 serial ports
    PUB Main
    Num.Init
    uarts.Init
    uarts.AddPort(DEBUG,31,30,-1,-1,0,0,57600) 'Add DEBUG port
    uarts.AddPort(NMEA,rx_from_nmea,tx_to_nmea,-1,-1,0,%000000,NMEA_BAUD) 'Add GPS NMEA port
    Pass_through(NMEA)
    PUB Pass_through (port) | Rx_byte
    ' infinite loop which simply reads from port and spits it to the debug port which should be the PST.
    repeat
    Rx_byte := uarts.rxcheck(port) ' collect byte from MACM port
    if Rx_byte <> -1 ' -1 means no data; don't do anything
    ' !outa[noparse][[/noparse]CAPTURING]
    uarts.putc(debug,Rx_byte)
    ' uarts.hex(debug,Rx_byte,2)
    Let me know if this looks useful but isn't explanatory enough. I can send more. I have to strip out the program that I'm currently working. However it shouldn't be too bad.
    good luck,
    pgb
    edited 2008-11-24 00:23
    Hi pgb,
    The data from the gps is OK as I have watched it on other TTL serial ports. I am just trying to use the capability built-in to the Micromega uFPU v3.1 floating point chip. It would save a cog as I could also use it for float math. It is somewhat working but very intermittent and it seems like sometimes the strings return garbage. It might be a matter of timing. Micromega has published routines for other processors so I may try it on a picaxe to verify the operation and see if there is a timing issue.
    The real author of the FPU object code has now joined the forum so maybe we can get some expert help. He has already submitted FPU drivers for several devices and it processes "version" SYNC and clock_ticks correctly every time from the FPU. It is only after I add the commands to start getting data from gps when it fails. There is something there I have not yet understood.
    After I have my second cup of coffee this morning, I will try to start a new thread for this subject.
    Donald
  • Jim PatekJim Patek Posts: 15
    edited 2008-11-24 01:43
    Hi shanghai_fool,
    I have spent the better part of the weekend trying to get the NMEA decode capability of the uFPU v3.1 to work. So far, all I have seen is garbage or nothing at all. The floating point routines in the FPU seem to work fine, so I assume I have the SPI connection set up correctly. Maybe I will try the I2C or try my new copy of ViewPort to see if I can see the signal on the SPI SOUT pin. However, I've run out of week end so it may be a while. Let me know what you find. I'd hate to have to give up on this function.
    Jim
    edited 2008-11-24 02:03
    Hi Jim,
    I have finally managed to get something. Looking at the picaxe basic program, I see how they use the different commands and check the status byte. Here is the snippet of the routine:
    PRI ReadGPS |temp
    FPU.WriteCmd2Bytes (FPU#_SEROUT,0,5) '; set baud rate to 4800
    Dbg.Str(string(" Baud rate set.. ",13))
    FPU.WriteCmdByte(FPU#_SERIN,4) '; enable NMEA serial input
    Dbg.Str(string(" NMEA enabled.. Waiting for input. ",13))
    repeat
    temp := 0
    repeat while temp <> $80
    FPU.WriteCmdByte(FPU#_SERIN,6) '; get gps string to string buffer
    FPU.WriteCmd($F1) ' read status
    temp := FPU.ReadByte
    FPU.WriteCmd($EC) ' Select string
    strPtr := FPU.ReadStr
    Dbg.Str(strPtr)
    Dbg.Str(string( 13))
    It returns the NEMA message type except the "$G" is missing. I knew it stripped out the "$" but I am not getting the "G".
    I will continue working with it. Maybe I cannot get the entire string at 1 time but that is OK. I will use the FPU to do the calculations anyway. At least there is progress.
    Donald
    edited 2008-11-24 02:11
    PRI ReadGPS     |temp
      repeat
        temp := 0
          FPU.WriteCmd($F1)
        FPU.WriteCmd($EC)
        Dbg.Str(strPtr)
    Sorry, I forgot to do formatted
    edited 2008-11-24 02:52
    Great, I'll give it a try. I uplugged my uFPU from the Propeller and breadboarded it up to a BS2 to try the code example that MicroMega provided ... worked like a charm. So I was trying to read BS2 and translate to Propeller. This will, no doubt, be faster. Thanks
    Jim
    edited 2008-11-24 03:15
    You should be able to use SERIN,1 and SERIN,3 to just pass through all characters but I haven't figured out how to read REG(0) yet.
    I am trying out my new LS20033 GPS @9600 baud but it doesn't work. I was getting the results above with an EM-411.
    edited 2008-11-24 03:40
    This bit of code extracts the Lat from the string. It gets the 4th field in the string, puts it in REG(A) and then prints it. I haven't figured out how to get the "FPU.WriteCmdByte(FPU#_STRCMP,string("PRMC"))" command to work yet so it only processes the GPRMC strings.
    [color=#000099]
        FPU.WriteCmdByte(FPU#_SELECTA, 1)
        FPU.WriteCmdByte(FPU#_STRFIELD, 4)
        FPU.WriteCmd($EC)
        uarts.Str(0,strPtr)
        uarts.Str(0,string( 13))
    [/color]
    I looked at the LS20033, but since I am working on robotic boats that move slowly I don't need 5 Hz. I can barely handle 1 Hz.
    Jim
    edited 2008-11-24 03:42
    Oh, yeah
    The "uarts.Str(0," is there since I'm using the multiple serial driver object. And the preceeding snitted goes at the end of your (shanghai_fool) code.
    jim
    edited 2008-11-24 07:01
    DarrenY,
    To your original request... "merely just make output := input?" ... You can implement two software inverters that will act like a buffer. Running at 80MHz, the propagation delay is 50ns.
    PUB SoftwareBuffer
        DIRA[noparse][[/noparse]Bpin1]~~                                       'Make BPin1 an Output
        DIRA[noparse][[/noparse]Bpin2]~~                                       'Make BPin2 an Output
        CTRA :=  %01001 <<26 | Bpin1 <<9 | Apin1            'Setup counter A for POS detector with Feedback mode
        CTRB :=  %01001 <<26 | Bpin2 <<9 | Apin2            'Setup counter B for POS detector with Feedback mode
        FRQA := 1                                           'Start Counter A
        FRQB := 1                                           'Start Counter B
    Beau Schwabe
    IC Layout Engineer
    edited 2008-11-24 09:09
    DarrenY,
    I think your solution would only work if you did it in its own cog, preferably in asm. Otherwise, you could not do anything else. The solution by Beau is much more preferable as it uses internal hardware built in to each cog and doesn't require any sofware other than setting up the counters. I am going to try that so I can monitor both the raw gps data and the FPU results simultaneously. I'm glad to see that someone is recommending using the timers. I think they are great and intend to put them to good use as pulse width detectors and frequency measurment.
    As far as the FPU, I·definitely think there may be a timing issue with my code. It works fine on the 1Hz EM-411 at 4800 baud but does not work with the 5 Hz. LS20033 @57600 baud.
    I am only getting the previous "Version..." string returned. It looks like it has not had time to process the command.
    I will have to work on this more.
    I would also like to be able to "pass through" the gps data stream using the SERIN,1 and SERIN,3 but have not been able to make that work yet. There is too much I do not understand about the FPU.
    You should be able to offload a lot of functions that deal with the gps data as these functions can be preloaded into the FPU.
    Data3.zip is EM-144, Data4.zip is LS20033. As you can see, the updates are 200ms apart.
    The FPU application notes are also attached.
    edited 2008-11-24 15:02
    Wow, thanks for all the input everyone.
    I really like Beau's method, i'll give it a try.
  • cessnapilotcessnapilot Posts: 182
    edited 2008-11-24 17:12
    Hi Jim,
    You should use the FPU.WriteCmdStr(...) procedure instead of the FPU.WriteCmdByte(...). The later one writes only 1 byte after the Cmd byte. Usually no terminating zero is transmitted in this case (depending on the address of your string) and that might even cause a hang up.
    edited 2008-11-24 19:47
    Hi sanghai_fool,
    It is recommended to use the "FPU.Wait" procedure before each(!) "FPU.Read..."·command, although not always necessary. In your code, however, where long NMEA strings are copied from here to there within the FPU, the FPU.Wait is definitely missing.
    Actually, the Propeller / FPU / GPS / Emic Text-To-Speech combination was the first successful trial for me to use the Prop with the FPU.·This mission programmable "screen less GPS helper" ·was done after the FPU AppNotes you mentioned and·a very early version of the FPU_SPI driver was developed for it.·The device·extracted the RMC·data·and spoke out useful information like "Airfield at 3 o'clock,·5 miles", or "Restricted Airspace·1 minute ahead". However, it was not loud enough in the cockpit, and once fell apart. It is waiting now for a good audio amplifier, a robust casing, not to mention the reprogramming. After I finish and put the Flight Simulator code and hardware on Obex, I will return to this project as I see·definite interest·on the forum about GPS data processing.·
    edited 2008-11-25 02:52
    Jim Patek said...
    [color=#000099]
        FPU.WriteCmd($EC)
        uarts.Str(0,strPtr)
    [/color]
    Jim
    Jim,
    Using your code, I detect the GPMC correctly but the dbg.str still drops the first char even in the Lat/Long values.
    PRMC Lat = 113.4646 Long = 2129.6787 Lat = aN Long = aN
    PGGA
    PGSA
    PRMC Lat = 113.4643 Long = 2129.6785 Lat = aN Long = aN
    Also getting NaN (Not a Valid Number) when trying to convert to FP like example.
    ····· FPU.WriteCmd5Bytes(_SELECTA,Latitude,_STRFIELD,4,_STRTOF,_FSET0)
    Latitude = 8
    I am using the "PC_Interface" object as dbg but it has the same str routine as the others.
    The string from the GPS is:
    ·$GPRMC,083707.000,A,3113.4643,N,12129.6785,E,1.56,176.83,241108,,*04
    I am not sure if the problem is in FPU or dbg.
    Still working with 4800 baud GPS.
    I added a FPU.WriteCmd5Bytes routine to the FPU object.
    So, making some progress.
    I am trying to follow the picaxe basic example to get started.
    Donald
    edited 2008-11-25 03:03
    Here are the files, so far. Please excuse all the extraneous coments as I usually do things "brute force" until I get things working then clean it up later.This is work in progress. tongue.gif
    edited 2008-11-25 03:24
    I don't understand this. I am trying to find the problem of the missing characters.
    Here is the code:
        FPU.WriteCmd(_READSEL)
        dbg.hex(strPtr,8)
        dbg.out(" ")
        dbg.hex(@strPtr,2)
        dbg.out(" ")
        Dbg.Str(strPtr)
    I am getting this:
    0000128C E0 PRMC Lat = 113.6103 Long = 2129.6421 Lat = aN Long = aN
    The "string" starts at $0000128C
    I thought the @strPtr should give me the first character.
    edited 2008-11-25 04:13
    Donald
    Don't know if it helps much but I get exactly the same results from your code.
    I switched it from "PC_Interface" to "FullDuplexSerial" and still get the same dropped initial characters.
    Will fool with it some more tomorrow.
    Jim
    edited 2008-11-25 04:53
    I don't know either. I think I will breadboard this up to the Picaxe and see if it works.
    edited 2008-11-25 08:07
    Well, it works OK on the Picaxe (although it would not compile until I had changed soe of the reserved words). It gets all 5 characters and the conversion functions return valid numbers.
    It looks like I have a timing problem with the FPU.
    Any ideas? I iwll change the clock pulses first as that is the easiest.
    edited 2008-11-25 13:34
    I have changed the _Read_Setup_Delay from 15us to 180us in case there was a debug program running that I was not aware of.
    I have changed the _Read_Byte_Delay from 1us to 2us.
    I have tried different terminal program.
    I have included fpu_wait before each read.
    All have same result. First character missing.
    Only 4 chars in buffer according to strsize.
    Things to consider:
    The correct data is in the FPU buffer or I would not get a match for "G1 byte "GPRMC", 0 "
    I don't know where I lose it.
    edited 2008-11-26 01:09
    Donald
    After looking at the AN039-GC Distance example, especially the user defined functions in the GCdistance.fpu file, I began to wonder if it isn't possible to leave most of the processing/manipulation on the uFPU. Assuming that we can retrieve floating point numbers from the appropriate registers without truncation (big assumption right now) it might be a way to sidestep the problems with the data truncation. or not, it may truncate numbers as well. I have played with it for a while and finally figured out how to load the user defined functions to the uFPU. Now if I can only figure out how to use them.
    One more question to show that I am apparently brain dead from this:
    In your code there is the line:
    [color=#000099]
    FPU.WriteCmdStr(_STRCMP,@G1)
    [/color]
    I don't see where the symbol "G" is defined. I assume that you mean the address of a string "G"? I am obviously missing something here.
    Jim
    edited 2008-11-26 02:45
    Jim,
    Thanks for looking at this.
    The G1 is from the DAT at the end of GPS_FPU_Demo.spin
    DAT
    G1      byte  "GPRMC", 0
    G2      byte  "Degrees"
    statusbyte    byte      0
    You are correct that most, if not all, of the desired functions can be carried out within the FPU by loading functions into either the EEPROM or Flash. I'm not sure what the difference is but one can be loaded via SPI but the other has to be loaded using the SERIN with the FPU IDE.
    That is the final result I am hoping to achieve but I am an old, slow, brute force first kind of programmer so I try to do some simple stuff first to get a handle on things. Both the prop and the FPU are new to me so I'm trying to learn the undocumented "features" stuff that makes things either work or not.
    Some things that are not well documented in the FPU instruction's which are apparently important in dealing with the SERIN,6 instruction is the STATUS byte.
    From the FPU manual
    SERIN,6
    Transfer NMEA sentence to string buffer. This instruction transfers the next NMEA sentence to the string buffer, and selects the first field of the string so that a STRCMP instruction can be used to check the sentence type. The status byte is set to greater-than (GT) if the sentence is valid, or lessthan (LT) if there is an error. If an overrun error occurred, bit 4 of the status byte will also be set. If a checksum error occurred, bit 5 of the status byte will also be set. If this instruction is the last instruction in the instruction buffer, it will wait for the next available NMEA sentence. It there are other instructions in the instruction buffer, or another instruction is sent before the SERIN,6 instruction has completed, it will terminate and return an empty sentence.
    but it doesn't really define the STATUS byte before the STRCMP which apparently can be different for different instructions but the other demo examples use $80 as the desired result of just the SERIN,6
    It looks like bit7 is always 1
    Bit0 is ZERO bit
    Bit1 is SIGN bit
    Bit4 is OVERRUN
    Bit5 is CHECKSUM ERROR
    The last sentence bothers me.·It seems that if·I send (via the FPU.SPIN) a command to read the status byte before the SERIN has completed, it will terminate and return an empty string.
    Some of the things I have done:
    wait 180us after the SERIN,6 command and then do a READSTR command before the READSEL.
    I get 1 or 2·complete GPRxx sentences, then it goes " off into the land of OoobLaDee".
    I think I may have to add a special call to FPU.spin to process the SERIN that will do the necessary waits and return the Status byte. Currently, the ReadCmdByte does not return anything.
    By examining the Picaxe and other examples, it queries the FPU directly and works OK.
    I just want to be able to understand the FPU calls and timing, then I will try to load functions and do the processing directly.
    The reading of the complete string and then the individual fields (temporarily verified by debug print) would be followed by the more complicated calculations. I am a simple-minded creature.
    I keep changing things around and get different results, but I'm sure its in the timing and sequence of the commands.
    I'll keep plugging away.
    Donald
