Interrupting a Larger Power Supply (how can i do this?)
Hello, I am a hobby coder and had a good experience with the basic stamp. I am now about to purchase a Propeller Start Kit.
I would like to know if (and how) it is possible to use the propeller to interrupt an electrical path.
In my case the propeller board would act as a power interruption unit for some devices that are downstream, so you would have the electricity some how passing through the grasp of the propeller then when I needed to I could cut off the power so the devices that are 'downstream' of the propeller would lose their electricity supply.
Consider the amount of electricity that of an average (american) household.
I considered using solenoids but could find very little info on solenoids other than solenoids used in water valves.
Does any one have information pertaining to this?
(as an extra question, would it be possible to measure the amount of electricity that is passing through?)
You can measure the current in a circuit by putting a small resistor in series and measuring the voltage across the resistor. Exactly how depends on the voltages and currents involved.
Post Edited (HobbyCoder) : 11/24/2008 3:26:08 AM GMT
See: www.x10.com/automation/x10_pl513.htm (This is the transmit-only version which works fine with the Stamps)
And: www.x10.com/products/x10_ck11a_ci.htm (This is the new version of the TW-513 for transmit and receive. I'm not sure if it works with the Stamps)
Some people have been experimenting with Propeller and the CK11A, but I don't remember how far they've gotten with it.
Post Edited (Mike Green) : 11/24/2008 3:44:06 AM GMT
