walky talkies hacked to be used for data transmition?
Hey so i saw these online 99$ 45 km radios and even thought the reviews all they that they really are only good up to 5 km (3.1 miles) is there a way that i could hack these to transmit code over that distance? If so i think i could probably double the 5 km range by using a stationary antenna. Especially considering these are rated up to 45 km!
Any ideas i am happy to hear them!
Post Edited (noobmuncher) : 11/25/2008 6:21:18 AM GMT
GMRS radios (which require a license to operate) and FRS radios (which don't require a license) are prohibited by law from transmitting data. Only voice and paging tones are permitted. It's easy enough to get an amateur Technician Class license, though, which permits data transmission in the VHF/UHF ham bands. The equipment tends to be a little pricier, however.
See Ken Gracey's thread regarding data transmission in the 2-meter ham band. I'm currently finishing up some modem software for the Propeller, which will interface with radios such as Ken's.
P.S. noobmuncher: Could you please insert your url text into a [noparse][[/noparse]url= ...] [noparse][[/noparse]/url] tag pair, please, to create a descriptive link? The url text is so long it's causing this thread to scroll horizontally. Thanks.
Post Edited (Phil Pilgrim (PhiPi)) : 11/24/2008 9:14:17 AM GMT
It's AFSK, 1200 baud (Bell 202). It requires a few external passives for filtering and a transistor for PTT.
Be careful Phil! The FRS rules/regulations have been modified a time
or two.
same way 'til I started seeing FRS units with built-in GPS. Apparently
Text messages can be sent via FRS now but, per the rules, have to be
manually initiated.
That's my bolding in the text below:
Sec. 95.193 (FRS Rule 3) Types of communications. (b) Non-voice communications. (1) The FRS unit may transmit tones to make contact or to continue communications with a particular FRS unit. If the tone is audible (more than 300 Hertz), it must be transmitted continuously no longer than 15 seconds at one time. If the tone is subaudible (300 Hertz or less), it may be transmitted continuously only while you are talking. (2) The FRS unit may transmit digital data containing location information, or requesting location information from one or more other FRS units, or [b]containing a brief text message to another specific FRS unit.[/b] Digital data transmissions must be initiated by a manual action or command of a user, except that an FRS unit receiving an interrogation request may automatically respond with its location. [b]Digital data transmissions shall not exceed one second,[/b] and shall be limited to no more than one digital transmission within a thirty-second period, except that an FRS unit may automatically respond to more than one interrogation request received within a thirty-second period.▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
-Rusty-
Rusty Haddock <=> AE5AE
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
Post Edited (Fe2o3Fish) : 11/24/2008 6:51:28 PM GMT
Thanks for pointing this out. I was aware of this exception (apparently initiated by Garmin), but the "one second in thirty" rule and the requirement for manual initiation seemed too restrictive for general-purpose back-and-forth data communication.
The way I'm reading the reg's, it doesn't appear that DTMF would be a permitted for data
comm in the Family Radio Service. But, IANAL either.
Noob,
Good luck with getting your ham license. You shouldn't need more than a Tech class
license for VHF and above (50-MHz and up) operations.
UAV --> Unmanned Amateur Vaccuum -- for remote dorm room cleaning!
Phil,
I totally agree. And we can thank our friends at Radio Shack for having the FCC to create
yet another CB and thusly the FRS!
-Rusty-
