Attempt at using Vmusic2 as Firmware update
I incorporated a Vmusic 2 onto a board and the mp3 aspect is working fine. Since there is a USB thumbdrive present at all times, I thought that the drive would serve as a nice method to remotely update the Propeller software. Below is what I wrote to FTDI, and the response is not encouraging, at least from my interpretation.
Is anyone here familiar enough with the Vmusic2 and Vinculum music firmware to know if what I am asking is doable?
I already have a bootloader, so I am not sure he is understanding my situation. Any thoughts appreciated. I want to transfer a file or parts of a file to an EEPROM from the usb drive, then reset the Prop.
Post Edited (TChapman) : 11/21/2008 10:34:53 PM GMT
Question said...
I have produced a prototype using the Vmusic2 schematic, I flashed the Vinculum with the music firmware, everything is working great as far as music commands.
I am looking into a method to allow a user to upgrade my processor software by copying the newest rev off my site, putting it on the usb drive, then on inserting the thumbdrive, the processor gets a command from Vinculum stating a drive is inserted. After that command is received, the processor reads the directory looking for a file named for example FW_1.13, upon finding a file with a number higher than a previously stored firmware revision, the user has an option come up on LCD that states "New firmware found. Do you wish to update your firmware now? Press yes/no. On "yes" the processor copies the file contents to a spare EEPROM, then verifies the transfer, then copies the contents to the main boot EEPROM, which is a simple read/write routine. My question is, does the recent music firmware offer capability to do what I have described?
Response said...
For upgrading your processor firmware you need some kind of bootloader running on your processor. And in fact that bootloader should read the files from thumb drive and carry out the flash operation. Since this transfer and reading is processor specific we cannot implement this in VMUSIC firmware. This is something you have to write on your own.
The bootloader in the Propeller's ROM only deals with the serial connection to the Propeller Tool on a PC and an EEPROM. FTDI was talking about you needing the equivalent that works with their Vinculum. You'll have to write it or find someone else to write it. It hasn't been done yet.
Yes, this is what I am wanting to know if I can do, to read a file, buffer it in ram while it gets written to the temp EEPROM, then re-read the file to verify the transfer, then copy the temp EEPROM parts to the main EEPROM location for read on the next boot. I will dig into the Vinculum and music firmware notes this weekend, but just wanted to not waste time if someone has already been down this road and determined is was not doable. I understand that it would be a major challenge to boot off the usb drive, that is not a consideration.
Thanks Mike.
Having never experimented with the binary file, I am assuming it is the carbon copy of what would exist starting at $00 on the boot EEPROM.
With the .eeprom you get what would be in the eactual eeprom after the bootloader has written it there. The binary is just a short version that relies on the propeller bootloader to add some extra guff prior to writing it out.
Pull my finger!
Don't forget the two extra longs ($FFF9FFFF) at the beginning of the stack segment. They are not in the .binary file also and contribute to the checksum.
Pull my finger!
1. Check the drive for a file with the beginning section of SWREV(+ word)
2. Extract the numbers following the prefix as a word
3. Check the current software rev word that is stored on the spare EEPROM as SWCurrentREV i.e. dec 12
4. If the number on the drive > SWREVX, display newer SW found, ask if you want to update now
5. If yes, start the transfer, OFR (open file for reading) then RDF (set read file length at 128) read file into UpdateSWArray[noparse][[/noparse]128]
6. Write UpdateSWArray to the first page starting at $00, set increment counter for next iteration read and write
7. Go back and read the next block, read and write until 32k has been read and written.
8. Read all bytes again, compare against spare EEPROM
9. If errors, fix the errors or report a problem.
10. Transfer from Spare EPPROM to boot EPPROM
11. REBOOT
12. Hope
OK, there are some 50 preferences stored on the spare EEPROM starting at $7000, I suppose I need to anticipate the future program length maximum, and assuming $7000 is a safe bet, do not copy from USB past $6FFF. But, when transferring to the boot EEPROM, I will write the whole 32k, the boot will ignore the preferences stored above $7000.
There is a verify from USB to Spare EEPROM, but no verify from Spare to boot EEPROM. Should I add the extra measure of comparing Spare to boot? OR USB to BOOT prior to REBOOT?
Post Edited (TChapman) : 11/22/2008 6:09:23 AM GMT
Well, seems like extra work to do this, why not just use the .eeprom, and transfer up to $6FFF leaving my prefs in tact? Then I don't have insert the extra longs.
I just saw your post Mike, thanks for those suggestions too.
Download from their site the newest update, rename the file to a fixed name they assign for it, put the file on a thumbdrive, insert the drive and it automatically updates. I see no point to try to determine the revision on the drive by name, if a certain file name is there, update. The user can just as easily overwrite the files or trash them as needed. The revision can live as a variable which can be displayed when needed to get the current revision.
Thanks for reminding me about the $FFF9FFF9. The FemtoBasic loader puts these in after reading the program from EEPROM or an SD card file when it's directly loading a program.
PUB SWupdateSet ser.str(2, string("SCS", CR)) ser.str(2, string("IPH", CR)) repeat ReadSetupKeys 'i2c read buttons if setupkeys == yesbut ser.str(2, string("OPR update" , CR)) '3E successful command here spk.beep(19, 2500, 200) if receiveStr(@MonitorUSBbuffer,3) <> CR quit if MonitorUSBbuffer[noparse][[/noparse]0] == $4E gotoxy(0, 0) ser.str(3, string("No Drive Present")) if MonitorUSBbuffer[noparse][[/noparse]0] == $43 gotoxy(0, 0) ser.str(3, string("Update Not Found")) 'file not found if MonitorUSBbuffer[noparse][[/noparse]0] == $3E '3E success here gotoxy(0, 0) ser.str(3, string("Update Found")) repeat while setupkeys == yesbut 'trap the button press until released ReadSetupKeys gotoxy(1, 0) ser.str(3, string("Continue? Y/N")) if setupkeys == yesbut 'ser.str(2, string("RDF", $80 ,CR)) ' $80 = 128 bytes to read,but any size fails "42= bad command" ser.str(2, string("RDF 128",CR)) '"42= bad command" 'ser.str(2, string("0x0B","0x20", "0x80", "0x0D")) "42= bad command" if receiveStr(@MonitorUSBbuffer,128) <> CR quit WritePage(eeprom2, $0000, @MonitorUSBbuffer, 128) gotoxy(1,0) ser.str(3, string("Write Complete ")) if setupkeys == nobut gotoxy(0,0) cls ser.str(3, string("Update Canceled ")) repeat while setupkeys == nobut 'trap the button until but released ReadSetupKeys gotoxy(1, 14) ser.hex(3, MonitorUSBbuffer[noparse][[/noparse]0], 2) 'show response byte 1 for reference if setupkeys == nobut gotoxy(0,0) ser.str(3, string("Update Canceled")) ser.str(2, string("CLF update" , CR)) if receiveStr(@MonitorUSBbuffer,3) <> CR quit spk.beep(19, 2500, 200) repeat while (setupkeys == yesbut) or (setupkeys == nobut) ReadSetupKeys if trap repeat while (setupkeys == leftbut) or (setupkeys == rightbut) ReadSetupKeys if (setupkeys == leftbut) or (setupkeys == rightbut) or (setupkeys == setupbut) return stop trap~Some stranger behavior, I get a 3E successful response on OPR file, but I get this response even if I rename the file on the drive, so this can't be right. There should be file not found when I rename it.
Also, I get a 42 "bad command" response when doing RDF 'size'.
The drive is working perfectly for all mp3 purposes, so I know there is not a drive problem.
Any suggestions appreciated.
ser.str(2,·string("RDF ",·0,0,0,$80,CR))
ser.str(2,·string("RDF ",0,0,0,128,CR))
the RDF command should be after the file has been opened.
Jeff T.·····
I made an eeprom file from the Propeller tool too, as well as a binary from bst, still it gives errors on finding the file, but finds my mp3's ok.
Post Edited (TChapman) : 11/23/2008 1:53:52 AM GMT
Thanks for the input.
What have done is set up a statement using full duplex using the basics of the common ReceiveStr, only I pulled out the if statement looking for CR or TAB, just let it count 128 bytes, return "0" when done.
So the jist of the main code is:
ser.str(2, string($0E, $20, "ppp", $0D) 'send hex OPRs 'RecieveStr , CR delimited string to get response of 3E, successful previous command ser.str(2, string("0x0B","0x20", "0x80", "0x0D")) 'send RDF size, 128 bytes, have also tried 8 byte if receiveStr(@MonitorUSBbuffer,128) == 0 quitThe ReceiveBlock locks up waiting on a response.
If I change the file name in the code or on the drive, it will respond File Not Found.
Upon booting and sending the first CR command to check on status, it responds with some initial info, probably disk info, serial, revision etc, but ends up with successful command response, so I let it get past all it's initial boot response first prior to sending the file commands.
Any suggestions on things to try would be very welcome.
The command was formatted $0B,$20, byte, byte, byte, byte ,$0D which would be $0B,$20,·0,0,0,$80 ,$0D
I apologize if I am reading the wrong manual or if you have already discounted this but I have to mention it again because I feel it could be important
regards
Jeff T.
After boot, the first command that is sent the Vinculum(doesnt seem to matter what command, CR is fine, it starts sending out its basic info, maybe serial, Firmware etc, then it sends out 3E to say it is ready. Interesting thing is, these first few bytes (maybe 32 -40, I forget) they seem to want to be sent in multiples of 4 bytes, and want to get a CR in return for each 4 bytes before moving to the next set.
I have made some progress using different methods to send the commands, below is half way working. The way the RDF ( file and specify how much to read) works is, you tell it the command, then state the size to get. If you tell it a size larger than the actual file, it will send the right amount, but it will pad the excess if you said too much. It seems to pad with FE. The problem is, that regardless of what size tell it, it thinks I am sending some massive number, and it sends the entire eeprom file, plus infinity FE's past the file. I tell it to get 8 bytes, it goes past the file into infinity FE, 32, 64, 128, all the same issue.
So, I set up a loop to display data as fast as possible on LCD, so I can see the correct file wizzing by, there are several obvious clumps of zeros, then the FE's.
Also, for some reason it is losing the first 12 or 16 bytes somehow when it copies to the spare eeprom, the spare starts several longs late, maybe 16 if I recall.
The Vinculum is rather picky about how you send it commands, I am in SCS short command and hex mode, but it still doesn't like me sending the file length in hex, no response, but using 0x00 or similar it responds.
Below is what is semi starting to show progress, although the infinity transmission is the real snag.
PUB SWupdateSet ser.str(2, string($0E, $20, "ppp", $0D)) 'send command to open file for read, gets success repeat ReadSetupKeys gotoxy(0,0) ser.str(3, string("Update Software?")) 'lcd if setupkeys == yesbut spk.beep(19, 2500, 200) ser.str(3, string("Reading Drive...")) 'lcd 'not sure if hex is sent msb, or lsb ser.str(2, string($0B, $20,"0x80","0x00", "0x00", "0x00", $0D)) ' '00000080 or 08000000 is same issue if ReceiveBlock(@MonitorUSBbuffer,128) == -1 WritePage(eeprom2, $0000, @MonitorUSBbuffer, 128) 'losing some bytes here gotoxy(1,0) ser.str(3, string("Write Complete")) spk.beep(19, 2500, 200) waitcnt(80_000_000 + cnt) repeat while setupkeys == yesbut ReadSetupKeys if setupkeys == nobut gotoxy(0,0) cls repeat while setupkeys == nobut ser.str(3, string("Update Canceled ")) ser.str(2, string($0D)) ShowMonitor ReadSetupKeys spk.beep(19, 2500, 50) repeat while (setupkeys == yesbut) or (setupkeys == nobut) ReadSetupKeys if trap repeat while (setupkeys == leftbut) or (setupkeys == rightbut) ReadSetupKeys if (setupkeys == leftbut) or (setupkeys == rightbut) or (setupkeys == setupbut) return stop trap~Not being sure of the Spin functions I'm not 100% on whats going on but it seems like you are enclosing the "bytes to read" in quotation, wouldn't that send a string rather than a number, what I mean is doesn't "0x80" actually transmit the string of hex values 30-78-38-30.
I might try something like ser.str(2,·string($0B,·$20,$0,$0,$0,$02,·$0D))·just to see if I could read two bytes to begin with or ser.str(2,·string($0B,·$20,0,0,0,2,·$0D))·, I might even try the same program code in ASCII mode ("IPA").
Jeff T.
Yes the device will respond to ascii, hex, etc. What you just wrote was what I have tried a lot: ser.str(2, string($0B, $20,$0,$0,$0,$02, $0D)) but the Vinculum just sits and does nothing. It only starts responding (wrongly) with what I have posted. I have tried all ascii in IPA as well, seems to make no difference, there is something still not quite right.
I will write FTDI, they are usually good about getting back in a day or so.
You can't send hex data to the Vinculum using ser.str, you must use ser.tx to send hex values.
Here is what works:
[noparse][[/noparse]code]
'seek to where you want to start reading
ser.str(2, "SEK"))
ser.tx(2, $20))
'word value of where to start reading in the file that is already open
ser.tx(2, $00))
ser.tx(2, $00))
ser.tx(2, $00))
ser.tx(2, $00))
ser.tx(2, $0D)) 'CR
'RDF "size" read the file, specify the amount you want to read.
ser.str(2, "RDF"))
ser.tx(2, $20))
'word value of amount of data you want to read at one time:
ser.tx(2, $00))
ser.tx(2, $00))
ser.tx(2, $00))
ser.tx(2, $80)) 'read 128 bytes
ser.tx(2, $0D)) 'CR
Jeff T.
I am actually surprised we don't see a lot more of Vinculum posts. The ability to read and write USB drives with this kind of simplicity is amazing.
I just read the USB drive containing the .eeprom file into the eeprom2(24cl256) starting at $00 up to $6FFF (At $7000 I am storing preferences). I then copied 64 bytes at a time from eeprom 2 to eeprom 1 starting at $00 up to $6FFF. There is a method to scroll through the lcd and get a visual of the bytes on each eeprom, they appear identical except after $7000. On the .eeprom file, there is nothing up that high except at $7F18 FF FF F9 FF FF F9 FF, which is present on the boot drive as I did not erase that high.
Scanning and looking from $0 to $6FFF looks identical, but the Prop will not boot from it. Any suggestions on what may be missing?
Cardinal Fang! Fetch the comfy chair.
