3 phase motor control through stamp
Okay so both me and remmi870 are trying to get a 3 phase motor controlled through a stamp although i am not sure we are thinking the same way. It was mentioned but how could i make a pwm just from the stamp 2px that a speed controller could interpret and get full power as well as no power to my motor. I do not need fine motor control, full on or completely off will do. If it helps i have a castle creations speed controller. Any help would be appreciated as well as any links to common themes to this. I understantd that i will need to have both digital and analog commands but have not found a diagram detailing what the wire set up is one the input to the speed controller.
There are 3 phase drivers that you can drive from any processor with pins for Direction, Enable(Run/Stop), Brake(if needed), PWM for speed or Voltage for speed.
Since you only want full on or off, you can drive a motor with Direction, and On/Off only.
If you don't have a motor driver, I can point you in some directions for either 3 phase driver IC's or complete 3phase driver boards ready to go.
anaheimautomation.com/brushless-dc-driver-mdc050-050051.aspx
This board uses a Motorola IC MC33035 3 phase motor driver, but instead of driving the fets they used the outputs to drive an Intersil HIP4086 N-Channel MOSFET driver IC, which driver 6 mosfets.
You can search for the parts on Digi, or google to see how they work. One thing about the board above is you can set the speed with a trim pot, then just turn the motor on or off as needed.
I have created a schematic for this combo as well in Eagle if you are a DIYer, it is all SMT, but should be simple to build with a solder pencil if needed.
# Power: 2200W
# KV: 230
# ESC Rating: 80A
and that comes out of my 11.1v lithium poly battery
So sorry i should have said that before
One thing i do not understand is normally with my speed controller and motor they would be controlled by a radio receiver because they are for a model airplane. In my set up i am replacing the reciever with the stamp 2px so it is autonomous with various other sensors providing input. So why cant the stamp just send out the small pwm signal for the speed controller then the speed controller can handle the high amps. From my understanding the pwm signal is rather small and simply is amplified, for lack of better word, into what drives the correct watts to the motor. Maybe my entire philosophy is wrong. I have been struggling to find good explanations into how this works so if you can provide one please do.
Why the rectifier?
Why the GTT?
This might be a stupid question but why cant i just make a simple pwm signal on my stamp and plug it into the speed controller? All i want is a neutral position, a full on position, and a full off position. That is it
Maybe i am missing something here
Post Edited (remmi870) : 11/21/2008 9:55:51 AM GMT
