My Code for my school Project is messed up, and I don't know why
Its a long line of code, but I'll point you out to specifically where it is messing up
Here is where Its messing up
What's happenning is the Middle Sensor goes extra buggy and crazy. It isn't properly detected 1 and 0. I don't even know why.
' {$STAMP BS2}
' {$PBASIC 2.5}
'{1 to 6 with a pause 20 is equivalant to 1 inch)
irDetectLeft VAR Bit
pulseLeft VAR Word
pulseRight VAR Word
loopCount VAR Byte
irDetectMiddle VAR Bit
hit VAR Nib
FINISH CON 4 'Just a constant of if a square is made
turn VAR Nib 'Will increase if a full corner turn is predicted
measure VAR Byte
'===debug variables===
horiz VAR Byte
vert VAR Byte
firstWidth VAR Byte
firstLength VAR Byte
secondWidth VAR Byte
secondLength VAR Byte
DO
FREQOUT 8, 1, 43000
irDetectLeft = IN10
FREQOUT 2, 1, 42000
irDetectMiddle = IN0
DEBUG CRSRXY, 2, 3, BIN1 irDetectLeft,
CRSRXY, 9, 3, BIN1 irDetectMiddle
IF (irDetectLeft = 0) THEN 'If the left eye sees a wall, boe-bot goes straight
pulseLeft = 850
pulseRight = 650
GOSUB Move
ELSEIF (irDetectMiddle = 0) THEN 'If the front eye sees something, boe-bot will turn to the right
DO
FREQOUT 2, 1, 43000
PULSOUT 13, 790
PULSOUT 12, 750
PAUSE 20
hit = hit + 1
LOOP UNTIL (irDetectMiddle = 1) 'Repeat the loop until the left eye sees a wall and the front doesn't
'===If hit is more than 4 then the boe-bot is most likely turning a long enough turn to hit 90 degrees===
' IF hit > 4 THEN
' turn = turn+1 'Add one to the turn variable to tell how many times it turned
' measure = 0 'The measuring resets
' ENDIF
ELSE 'Should turn slightly to the left if both eyes don't see anything, just until the left sees a wall
pulseLeft = 780
pulseRight = 650
GOSUB Move
ENDIF
'=====Check if Boe-Bot made a square or rectangle====
IF (turn = FINISH) THEN
EXIT
ENDIF
hit = 0 'reset hit
LOOP
END
'===Statement for printing out the drawing and calculating measurement===
debug_Rectangle:
SELECT turn
CASE 0
vert = measure
firstLength = measure
DEBUG CRSRXY, 0,vert, "|"
CASE 1
horiz = measure
firstWidth = measure
DEBUG CRSRXY, horiz,0,"-"
CASE 2
vert = measure
secondLength = measure
DEBUG CRSRXY, horiz, vert,"|"
CASE 3
horiz = measure
secondWidth = measure
DEBUG CRSRXY, horiz, vert,"-"
CASE ELSE
'When turn = 4, the debug prints out the info
DEBUG CRSRXY, horiz+2, vert+2,"Area is between : ",DEC (firstWidth*firstLength), " and ", DEC (secondWidth*secondLength)
DEBUG CRSRXY, horiz+2, vert+3,"Perimeter is between ",DEC ((2*firstWidth)+(2*firstLength)), " and", DEC ((2*secondWidth)+(2*secondLength))
ENDSELECT
RETURN
Move:
FOR loopCount = 1 TO 5
PULSOUT 13, pulseLeft
PULSOUT 12, pulseRight
measure = measure + 1 'Counts how many inches is traveled
PAUSE 20
NEXT
RETURN
DO
FREQOUT 8, 1, 43000
irDetectLeft = IN10
FREQOUT 2, 1, 42000
pulseLeft = 850
pulseRight = 650
GOSUB Move
DO
FREQOUT 2, 1, 4500
PULSOUT 13, 790
PULSOUT 12, 750
PAUSE 20
hit = hit + 1
ELSE pulseLeft = 780
pulseRight = 650
GOSUB Move
ENDIF
