Negative pin voltage?
I just got my first PCB back. Of course I made a few errors, but it seems to work. Except for one thing. Has anyone seen a negative voltage on a propeller pin? I have a NPN transistor that is supposed to fire a camera when pin 23 pules high, but all I get off it is -.4 V. When I set pin 23 to an input, and 22 high, and short the two, the camera fires, leading me to believe that the transistor is good. Any ideas?
You may have damaged P23's output buffer, I'm sorry to say. Your transistor base circuit is missing a series resistor, which is necessary to limit the base-emitter current. If you want to jury-rig something, cut the trace from P23 and install a 2.2K resistor there. If that doesn't work, pick another pin to solder the resistor to. You should also replace the transistor, since it likely got damaged as well.
'Just a few PropSTICK Kit bare PCBs left!
There is always the assumption that your test instrument is perfect and that it is hooked-up correctly. Never assume. The -0.4V could be because you are not actually connected to ground or it could simply be induced voltages on a high-impedance input that are being clamped by the chip. This is only minor anyway but your problem with pin 23 and 22 sounds strange, I think that a look at your actual pcb and layout may reveal the answer.
*Peter*
P.S. Yes, you need a current limit resistor and is the negative voltage still there when you have the camera disconnected?
Post Edited (Peter Jakacki) : 11/19/2008 11:20:43 PM GMT
The only way you could get a negative voltage is if there's an error somewhere on the PCB so that some points that are supposed to be grounded actually float somewhere above ground. If the supply to the Propeller chip is such that part of the board's ground connections float 0.4v above the ground voltage for the Propeller, then the I/O pins could look like they're below ground when measured against the other (higher) part of the ground system.
As for the impossibility of a negative voltage, I agree with the theory, but that's not what I'm seeing. I measured every ground to every other ground, and read 0 volts, and from the battery ground and the propeller ground to the propeller +3.3 and saw *3.27. So it looks there are no floating grounds. But when I measure from any ground to pin 23 I'm seeing -.4 volts. And when 22 is high I'm seeing +.4 volts, not 3.3. I'm perplexed.
Again, if your PCB provides the circuitry shown in your schematic (other than the lack of a current limiting resistor), it should work and there should be no way that the Propeller can produce a negative voltage on an output pin. Since you're finding a negative voltage on an output pin, either your Propeller chip is broken or the PCB and your schematic don't really match or both.
When a pin is an input, you can see any voltage between -0.6V to +3.9V. This is because the pin is floating and any gate charge that's built up on the input capacitance will not get bled off by the protection diodes, unless it's outside that range or the chip is unpowered. I wouldn't worry about it. The +0.4V you're seeing on P22 could be the forward voltage of the transistor's base-emitter junction if you still have it connected; and/or you may have fried P22 as well.
Time to do some desoldering, order a new (and improved) board and a new propeller. Thanks guys.
When you drive a grounded-emitter transistor without a base resistor, it's nearly the same as driving a dead short. I'd've been more surprised if the pin had survived.
Andy
I don't know why you are seeing a negative voltage, however in a very rare circumstance you could have created a very small "solid oxide" fuel cell during the process of damaging your I/O pin. The problem is that a SOFC requires heat in the oxidized area to function. I suppose it could be getting some heat from the damaged I/O ... If there was a sufficient amount of heat, it would be in the right area for this to happen.
How much current is your Propeller drawing when you are reading the negative voltage?
Reference:
http://en.wikipedia.org/wiki/Solid-oxide_fuel_cell
That said, I tend to lean with Phil though... If the pin is floating then anything could be seen... check to see if you can actually drive the pin low or high in the first place.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 11/20/2008 6:12:47 AM GMT
