Propeller General Questions — Parallax Forums
SRLMSRLM Posts: 5,045
edited 2009-10-03 00:33 in Propeller 1
Okay, I've been sitting on these for a while, in the hopes that I could find the answer somewhere. They haven't shown up, so here goes.
Is there a single reference for memory and how to access it? I can look at the Propeller diagram (the one with the cogs as squares, and the four lines below and IO pins to the right) and see the basics of how memory is allocated. Yet, what's the difference between cog RAM and hub RAM? Is is access capabilities? How do I differentiate between the two? To access the EEPROM memory, do I need to start up an I2C object, or can I just reference it with a simple command?
Second: when I create an object (in the OBJ block), do I launch that into a new cog, or is it simply a way to import more code into the current cog? If it's not automatically launched, how do I put it into a new cog? COGSTART only works with a method, right?
What is the most efficient way to exchange data between cogs? Address? Passing by value?
Thanks for any insights...
    edited 2008-11-19 01:49
    1) With regard to your question, there's only cog memory. Each of the 8 Propeller processors (cogs) has its own 512 x 32-bit word memory. These 8 memories are completely independent of each other and are accessible only to the cog attached to it. When a cog is "booted" using COGNEW/COGINIT executed either by the same cog or another one, the cog's processor is forced to load up the whole 512 x 32-bit word (or 2K byte) memory from hub memory, then is started with the instruction in location zero.
    What is referred to as "hub" memory is a completely separate block of 32K RAM (and 32K ROM) that is accessible from each of the 8 cogs using a commutator (or hub mechanism) and a group of special instructions for reading (RDBYTE/RDWORD/RDLONG) and writing (WRBYTE/WRWORD/WRLONG). Think of this memory as an I/O device rather than conventional memory.
    2) The EEPROM attached to I/O pins 28/29 is one of the possible sources of information to be initially loaded into the hub memory by a bootloader in ROM, the other being an attached PC using a special protocol. Once the hub is initially loaded, these I/O pins (and the EEPROM) are no longer needed. The EEPROM can be accessed using a variety of routines available from the Propeller Object Exchange. Some of these are written in assembly language and would run in a separate cog. Some of these are written in Spin and can be incorporated into your own program as the individual subroutines (methods) or referenced as objects.
    3) Objects do not automatically start up routines in separate cogs. Objects are just ways to package up a set of subroutines and functions along with private data. Some of these objects need to start up a separate cog to do their "thing" and these will generally provide a start routine, possibly with some parameters, that will do this for you.
    4) Sharing data between cogs is normally done by sharing variables. If the cog code is in Spin and all the routines involved are in one object, you can literally just use the same variables in both sets of routines. If the cog code is in a separate object, you will probably have to pass the address of the shared area to the separate object. There are plenty of examples in the Object Exchange of sharing simple scalar variables to complex buffers and their pointers. "Most efficient" depends on what you're doing, how you've organized it, and what you intended.
  • SRLMSRLM Posts: 5,045
    edited 2008-11-19 02:22
    3)Okay, so to launch an object into a new cog, I have to use COGNEW or COGINIT. However, these commands take a method argument. If that method references other methods (within the object) then do those get imported as well?
    An example:
    'Object Number
    OBJ
       debug : "FullDuplexSerialPlus"
    VAR
       long Value
    PUB ADD
    PUB SUBTRACT
    PUB OPERATE
    Say I launch OPERATE, and operate calls ADD and SUBTRACT. Are those methods ported to the new cog too? Also, does the same thing happen for objects in that objects OBJ block (like the debug object)?
    4a) So, in the above example, if I were to use the OPERATE method to launch the ADD method into a new cog they would both be able to manipulate Value at the same time?
    4b) Do the addresses of COG ram restart at 0 (or an identical value) for each cog, or do they build (cog 0 is 0 - 511, cog 1 is 512-1023, ...)
    4c) Can one cog use a variable address to access another cogs data?
  • Ron FrazierRon Frazier Posts: 11
    edited 2008-11-19 03:18
    Hello all.· Just starting to get my feet wet with the Propeller.· I have not done any of my own programming as yet on the chip.· I'm trying to understand the memory model at an overview level.· So, my understanding is that each cog has 2K of it's own ram, which gets loaded from hub ram when the cog is booted.· So, to load all 8 cogs with different programs to their full capacity would use up the 2K on each cog, as well as 16K of hub ram for the source of the programs.· Is the other 16K of hub ram available for general purposes?· Or, is that where the bootloader, character generator, and math lookup tables are stored?· If those things are not stored in the other 16K of hub ram, where are they stored and how are they accessed?· Is it possible to run cog programs bigger than 2K by bank switching the code in and out?· Also, is it possible to use an eeprom bigger than 32K?· Finally, is there 16K of available space in the 32K eeprom?· Thanks in advance for any replies.
    Sincerely,
    Ron
    edited 2008-11-19 04:49
    Ron,
    The bootloader, spin interpreter, font tables, and math tables are all stored in 32K of masked ROM on the Propeller chip at addresses $8000 to $FFFF in the hub address space (32K of RAM is at addresses $0000 to $7FFF).
    You're correct in that 8 cogs x 2K bytes for a unique cog ram content per cog equals 16K. Typically, cog programs don't take the full 2K and the rest of the cog is loaded with whatever comes after the actual code from the hub memory (this is typically ignored or used for uninitialized data areas).
    You can't do bank switching because there are no banks to switch. What you can do is to load other code into the cog from hub memory (fastest) or external EEPROM as an overlay.
    You can use an EEPROM larger than 32K. They're available in sizes up to 128K bytes and you can use up to 4 of these. Only the first 32K is recognized by the bootloader and the Propeller Tool, but you can store programs and data there by using any of several programs that act as an operating system. The first 32K is assumed to contain the program to be started up on a reset, but any EEPROM past the end of the program can be used for data although it's erased the next time a program is downloaded from the PC to the EEPROM.
    SRLM,
    Objects and cogs are separate concepts. You can have routines all contained in one object that execute in different cogs. You can have objects that contain routines that never use additional cogs. You can have all sorts of combinations as well.
    The 8 cog ram areas are completely separate and, as I said, are only accessible from the associated cog. Each of the cogs is a separate processor with its own memory and arithmetic/logic unit. The cog's ram cannot be accessed by another cog or any other part of the chip.
    Spin is executed by an interpreter (a program) written in Propeller assembly language and stored in ROM. When the chip is reset, a copy of this interpreter is loaded into one of the cogs and executed (after the bootloader has finished). It is this interpreter program that "executes" the Spin program stored in hub memory. The Spin source file is compiled into a bytecode format and this is what is downloaded into the Propeller's ram on a reset from the Propeller Tool running on a PC. The bootloader can copy the program from ram to the EEPROM and that copy is what's used when a PC is not present.
    edited 2008-11-19 10:22
    Mike, thanks for the reply.· That brings up some more questions.· References to other links with answers are fine.
    quote -->
    <--quote
    1) So, was my assumption that there·is 16K of hub ram free, which is not used as the source for loading cog ram, correct?· Can this ram be used for any other purpose I want in my program?
    2) How can I determine how much cog memory is used, and how much can be used for other purposes.· Sorry if that's in the manual.
    3) Say I declare an array, for example, in cog ram.· If I use only symbolic names, no physical addresses, does the compiler handle all the memory mapping?· What if the size of the array exceeds available ram?
    quote-->
    <--quote
    4) Say I have a cog program which is using 1K of memory, leaving 1K free.· If that program is doing a supervisory role and switching overlays in and out, how would I go about loading the overlay, then having it execute, then returning control to the supervisor?
    quote-->
    <--quote
    5) How would I hook up more eeproms?· Do they attach to the same circuits and the existing eeprom on the Prop demo board?· How are they addressed?· Are they using I2C to communicate?· How would I load them?
    6) It sounds like you're saying I would have to load the program with the propeller tool, which erases all? the eeproms.· Then I would have to reload the eeproms.· Then they would be accessible to the program.· Would they still be accessible beyond 32K after a reset, assuming I don't reprogram?
    quote-->
    <--quote
    7) Which cog will the interpreter load into, if there is only one?· I understand that the interpreter loads in any cog which is running any spin code.· Is that correct?
    8) How much cog ram does the interpreter take?
    9) Does the spin code get stored· in cog ram, or only hub ram?· If hub ram, does that mean a spin instruction can only execute every time the hub ram·becomes accessible to that cog?· I understand that the assembly instructions can execute at 20 MIPS with an 80 MHz clock.· How many spin instructions can execute per second?
    10) I think I read somewhere that some spin code must exist in at least one cog, even if the application is all assembly.· Is that correct?
    11) I think I also read that it is possible to have all assembly in a cog, if it is kickstarted by spin in another cog.· Is that correct?
    Thanks for the help.· There are many implications to this architecture, which are initially difficult to wrap one's brain around.
    Sincerely,
    Ron
  • shanghai_foolshanghai_fool Posts: 149
    edited 2008-11-19 12:41
    Ron,
    I understand where you are coming from. I can see where you misunderstand some of the Propellers properties just as I did and still do. I have tried to download and read everything I can find as I run into each thing I need to do. I am interfacing a lot of different devices one at a time and just try to learn as I go along. Its much the same as I had to do about a hundred years ago with the 8080 and Altair. Nobody that knew anything was talking so I just had to learn on my own.
    Unfortunately, I have not found much involving learning assembly for the Prop. The manual gives some explanation for the instructions but nothing like it does for Spin.
    I am sure there is a wealth of information here iin the forum but it takes so long to find it. The search engine is worthless. I know because it can't find stuff I know is there. And there is only one forum with no breakdown by subject type.
    I am currently having problems trying to pass parameters between objects. I have done it for a couple of items using the same ethod I have seen in other programs but have found no real explanation for it anywhere. I cannot find any tutorial on using the @ for passing mutilple parameters or how to use the @stack.
    Like you say, the memory model is not very well explained. Although it is stated that a mix of spin and assembly is used in each cog, that is not the case. When assembly code is loaded into a cog, it starts at org 0. There is no place for the spin code to reside. It doesn't state where that is. All parameters are passed between the cog memory and main memory. I do know that the cogs operate independantly at the same time and only "slow" down if waiting to transfer data to/from main memory. Thats when it has to wait for its time slot. It seems that you can run either spin or assembly in a cog but not both at the same time.
    Yes you can load different programs into cogs. You can start a cog with a certain function and when finished, stop the cog which releases it for any other method that needs it.
    I am not very good at explaining the items you mentioned especially when I am also tring to learn the same things. I am sure there are much more qualified people on the forum to do that. I'm also sure the questions are not new and the answers are probably here if we could just find them.
    Good Luck,
    Donald
  • mparkmpark Posts: 1,336
    edited 2008-11-19 15:12
    shanghai_fool said...
    ...Although it is stated that a mix of spin and assembly is used in each cog...
    Where is that stated?
    edited 2008-11-19 15:38
    Note: All of this describes the "native" Spin / assembly environment. There is a commercial C compiler that uses a different kind of programming environment where there's some interpretation and some direct execution in the cogs and variables can be explicitly allocated in cog memory. You'd have to download and read the documentation from ImageCraft to get the details. There's also a Forth implementation that similarly allows a different use of cog memory.
    1) Lets back up a moment first. The Spin compiler puts out a "binary" file which gets downloaded to the Propeller's hub ram (and perhaps the attached EEPROM). This file consists of several different things: a) Spin interpretive bytecodes for the "main program" and routines that it calls; b) assembly language instructions to be loaded into some cogs when needed; c) global variables and constants. Spin is a stack-based environment, so there's a run-time stack that starts at the end of the loaded program and extends upward in memory as needed. This stack is used for subroutine (method) calls including local variables. If you start another copy of the Spin interpreter in another cog, that requires its own stack space which is usually an array variable declared somewhere in the program. What's left of the 32K hub ram can be used for other things. Some of the display drivers use this space for a display buffer, particularly the TV bitmapped graphics driver(s).
    2) We're only talking about 496 words here. The compiler does have a FIT directive to check that a chunk of code will fit into a cog with a specified amount of memory remaining (for buffers, etc.) Other than that, there's no checking.
    3) Again, cog ram is used only for assembly language. There's no high level structure like arrays. The compiler doesn't allocate variables in cog ram.
    4) You write your supervisory routine to do what you want. There are instructions to read from hub memory to cog memory and, once a block of data is copied, you can jump to the beginning of the block.
    5) It sounds like you need to learn how I2C EEPROMs work and how they're connected. More can be connected to the same I/O pins as the existing one or they can be connected to other I/O pins. As far as the Propeller is concerned, one I/O pin is just the same as any other. There are standard routines available for I2C I/O.
    6) The Propeller Tool erases the 1st 32K of EEPROM when a program is downloaded. It doesn't access any EEPROM beyond 32K.
    7) It doesn't matter. All the cogs are identical. Normally, the hardware picks a stopped (idle) cog to use (see the COGNEW instruction description).
    8) All of it
    9) Spin code is stored in hub ram. The execution time for Spin bytecodes is variable (because they do things of widely varying complexity), but generally is on the order of microseconds.
    10) When a program is started, the Spin interpreter is always the first thing executed by the bootloader. As a result, a program must consist of at least a short stub that just replaces the Spin interpreter with a user supplied assembly program. This can be done with a 16 byte program prefix.
    11) I think you need to work through some of the tutorials. There's a set of them that are intended for use with the Propeller Education Kit and there are some other tutorials, all linked from the "sticky" (permanent) forum threads at the beginning of the Propeller forum thread list. Most applications are written entirely in Spin and, as far as the user is concerned, that's the programming language. There are all sorts of library routines (objects) in the Propeller Object Exchange that take care of most high speed I/O and parts of these are written in assembly language that the user doesn't normally see or have to worry about. These include video display drivers, PS/2 keyboard, asynchronous serial I/O, servo motor control, analog to digital conversion, and objects for handling specific external devices. Download some of these and look at the demo/example programs that are included.
    edited 2008-11-19 16:19
    mpark said...
    I think I saw it here in the forum but I obviously can't find it. The search doesn't even find this when I cut and paste the exact words. I do know that you can mix assembly and data but unless you know where the spin code ends, you would not know where to place the org for the assembly. Maybe someone thought this and posted it but I can't remember where in the 300,000+ posts it was. I've only read maybe 500-600 of them. Like I said, I'm still learning this also.
    Sorry if I misspoke
    edited 2008-11-19 17:04
    I think you can't find it because it's just not true. A cog can execute an assembly program and, by executing the Spin interpreter (a program written in assembly and stored in ROM), a cog can effectively execute Spin code.
  • Ken PetersonKen Peterson Posts: 806
    edited 2008-11-19 17:30
    The SPIN interpreter is carefully designed so that it can fit into cog memory. It takes practically every available long in cog memory, so it is not possible to run SPIN and assembly in the same cog. You can have a mix of both SPIN and assembly in an object, but only one or the other can be run with a cog. This is why it is always necessary to start a new cog to run assembly.
    Keep in mind that objects are not loaded into cogs. Objects are just a way of organizing code and providing data encapsulation so code can more easily be re-used. Cogs run either PASM code or a separate SPIN execution process with the interpreter. SPIN code is never loaded into a cog directly. It is read statement by statement from HUB RAM by the SPIN interpreter as it executes.
    Since SPIN is executed directly from HUB RAM, all SPIN processes have global scope, even if launched on a separate cog. PASM, however, runs in it's own little world (cog memory) so it needs to access HUB RAM using the HUB access statements (rdlong, wrlong, etc.).
    ·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
    - Bjarne Stroustrup
    Post Edited (Ken Peterson) : 11/19/2008 5:56:04 PM GMT
    edited 2008-11-19 17:57
    I highly recommend DeSilva's Machine Language Tutorial for getting to understand Propeller Assembly.
    http://forums.parallax.com/forums/default.aspx?f=25&m=209237
    Although English is not his first language, he covers the material in great depth and does so with enthusiasm and a bit of dry humor. I found it to be a good read.
    - Bjarne Stroustrup
  • BradCBradC Posts: 2,601
    edited 2008-11-19 18:14
    Ken Peterson said...
    I will second, third and sponsor that recommendation. I also wish he'd get over it and come back. He is greatly missed.
    Pull my finger!
    edited 2008-11-19 20:38
    Mike, shanghai fool, just wanted to say thanks for the replies.· I'm sure I'll revisit this information periodically.· Guess I have to jump on the tutorials.
    Ron
    edited 2008-11-20 01:01
    Thanks Ken, I had found that once before and read it but I was probably looking for a reference for a particular point which, at the time, was not addressing. I have been able to rdlong PAR PAR+4 etc. but now want to pass an array and was trying to make it more complicated than it actually is. It is just RDLONG * (N+4). I just rembered RDBYTE.
    Donald
    edited 2008-11-22 03:12
    Okay, so all objects live in the hub all the time, and only assembly gets loaded into a cog? If Spin only lives in the hub, is there a way to access the cog memory? I'm assuming that the memory set aside with VAR and | is all placed in the hub.
    Also, how do I assign an address to a variable (what it the syntax)?
    here is what I want to do:
    @variable1 := @variable2
    so that whatever changes I make to variable1 are reflected in variable2, and vice versa.
  • sylvie369sylvie369 Posts: 1,622
    edited 2008-11-22 03:27
    SRLM said...
    Okay, I may be off here, but if they've got the same address, how can they be two different variables? Is it just that you want to call a variable by two different names?
  • Harrison.Harrison. Posts: 484
    edited 2008-11-22 03:30
    SRLM said...
    There's no provision to access cog memory in spin. You can access the 16 SPRs (special purpose registers) in each cog by using SPR[noparse][[/noparse]idx], but there's no way to access the entire cog memory. I believe hippy was able to obtain cog memory access through some very sneaky coding, but it is unrealistic for real applications. Accessing cog memory wouldn't get you anything other than the interpreter source code since no user code is loaded into a spin cog. All user variables are stored in HUB memory.
    SRLM said...
    There are no pointer variables in spin. You can get the HUB address of a variable via @symbol, but you cannot assign an address to a variable. The method of choice to share variables using memory addresses is to use the long[noparse][[/noparse]hubaddr], word[noparse][[/noparse]hubaddr], byte[noparse][[/noparse]hubaddr] 'arrays' in spin.
    Basically you would do something like this:
    VAR
      byte var1
      long ptrVar1
    PUB main | i
      ptrVar1 := @var1
      i := byte[noparse][[/noparse]ptrVar1]
    edited 2008-11-22 03:58
    You can also assign values to variables pointed to by pointers.
    VAR
      byte var1
      long ptrVar1
    PUB update(i)
      ptrVar1 := @var1
      BYTE[noparse][[/noparse]ptrVar1] := i
    You wouldn't use it as such. But you might want to pass a variable to a child object which would modify the value of that variable. The only way you can do that is by passing the address of the variable because the variable name is not in scope within that child object.
    There is no access to cog memory directly except by the code running within the cog. If you want access outside of that cog, you have to provide a means within the code running in the cog to access it. There are many ways of doing this. The simplest and most obvious is to copy values to HUB periodically or when needed, to make those values available to other cogs.
    - Bjarne Stroustrup
    Post Edited (Ken Peterson) : 11/22/2008 4:13:03 AM GMT
    edited 2008-11-22 06:32
    Okay, a clearer picture is starting to form...
    I'm still wondering about inter-object variable sharing. To me, it seems the most logical to have a spot on the heap that both programs look at, one to read and one to write.
    My background on this is that I want to make a program to pulsout servos: I launch this into a cog and it sends the pulse every 20 ms. In order to update the pulse width, it should read a spot in memory that is updated by the main program. This way, I never have to do a call (from main) like
    servoControl.setWidth(1500)
    servoControl.pulse
    waitcnt(clkfreq/1000*20 + cnt)
    Rather, I could just do something like
    pulseWidth = 1500
    Thanks for all the help!
    edited 2008-11-22 07:03
    Check out Servo32 in the object exchange. It does exactly that and you could see how it is done.
    http://obex.parallax.com/objects/51/
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2008-11-23 23:28
    Great discussion on the most mind-bending aspect of the prop world.
    Thanks to all.
    Jim-
    Signature space for rent, only $1.
    Send cash and signature to CannibalRobotics.
    edited 2008-11-24 03:54
    Another question: if Spin lives in the hub, and the interpreter lives in the cog, then how does code get interpreted. I've got the part about the hub going in a round robin fashion, so I assume that a certain amount of the spin code is downloaded to the interpreter? This sounds inefficient in the least...
    Oh, and thanks for all the answers!
    edited 2008-11-24 04:04
    There are instructions (RD/WR-LONG/WORD/BYTE) for transferring data between hub memory and the cog executing the instruction. The Spin instructions are read byte by byte as they're interpreted. If the timing is done properly, there's little inefficiency. The same instructions are used for reading and writing data used by the Spin program (which are also stored in hub memory).
    edited 2008-11-24 04:43
    Following on from Mike...
    The spin code lives in hub. The spin interpreter (interpreters if more than 1 cog running spin) lives in cog ram and is written in pasm. Each byte is fetched from hub by the pasm interpreter and decoded and a routine (set of pasm instructions) executed, depending on the bytecode.
    Loading the bytecode may take up to 16 cycles to fetch each byte. The pasm code decodes (interprets) the bytecode(s) and executes a set of pasm instructions (resident within the cog) to perform this. This is common to all interpreted languages. The variables and stack are located in hub, but pointers to these bases are held in cog ram.
    If you wish to investigate further I suggest you look at my articles Faster Spin Interpreter and Spin and Pasm Debugger with Zero Footprint. If you download my demo you can see how many pasm instructions are executed for each spin instruction - it will trace these instructions (pasm and/or spin).
    edited 2008-11-24 06:08
    So Spin lives in the hub, but it doesn't actually do anything there. Rather it's tossed to the dogs (cogs so to speak), and is broken down into assembly code, where it gets executed.
    Mike said...
    How do I do the timing? It seems difficult to do when I don't know how much assembly is generated from a Spin command (that is what it does, right?)
    So if the spin is always interpreted, why not "pre-interpret" it before loading it onto the chip? Isn't that what a compiler does?
    Edit: Cluso99 Can you provide a link? Google couldn't seem to find a literal for the titles you provided...
    Post Edited (SRLM) : 11/24/2008 6:15:13 AM GMT
  • AribaAriba Posts: 2,697
    edited 2008-11-24 07:47
    SRLM said...
    The assembly code is not generated by the Spin commands, it stays already in the cog. And the proper timing has been done by the author of the interpreter (Chip himself). You can see the Interpreter cog as a virtual CPU which executes bytecode from the Hub RAM.
    SRLM said...
    The bytecode is the "pre-interpreted" result of the Spin compiler. Spin is a combination of compiler and interpreter: The compiler generates the intermediate bytecode, and the "interpreter" executes this bytecode. The reason for this is:
    1) the bytecode is much compacter as a generated assembly code (important because of the limited Hub-RAM size).
    2) Assembly code can not be executed directly from the Hub RAM, and the cog RAM is too small for bigger programs.
    Another methode (used by the C compiler) is LMM, where the compiler generates assembly instructions in the Hub RAM, which are loaded and then directly executed by a LMM interpreter in a cog. This is faster than Spin bytecode, but uses much more RAM for the same functions.
    Andy
    edited 2008-11-24 08:27
    Here are the links
    PASM and SPIN debug with Zero Footprint http://forums.parallax.com/forums/default.aspx?f=25&m=290946
    Spin Interpreter - Faster??? http://forums.parallax.com/forums/default.aspx?f=25&m=273607
    This is where I find them:
    Prop Tools under Development (Index) http://forums.parallax.com/forums/default.aspx?f=25&m=296149&p=1
    Open Office file which contains an index of all Propeller Forum postings http://forums.parallax.com/forums/default.aspx?f=25&m=305797
    As Ariba says, the interpreter runs a set of predefined pasm instructions for each bytecode (or sequence of bytecodes).
    edited 2008-11-25 00:32
    Thank you all very much! I've now gotten some autonomous servo control: set it and forget it (hmmm, sort of like the PSC) Anyway, another question has arisen: I'm passing the address of a variable to an object, then it uses code like
    pulse := LONG[noparse][[/noparse]newPulseAddress]
    My question is: can I be writing at this address the same time as I'm reading it? I think this may be the part about the hub going around in a round robin fashion...
    edited 2008-11-25 00:49
    The hub parcels out read/write cycles so that each cog gets an individual chance at access, so you can't really do two operations at the same time.· You can do a write and a read, each in a separate cog, very close in time and, as a result, your program can behave unexpectedly if you don't plan for the interaction.
