Using Prop as RC interpreter
I'm involved with the Robotics Team at my university and we are just getting things off the ground. I'm one of the lead electronics people on the team and will be responsible for most of the electronic components of the robot. This is a fighting robot, btw, for BattleBots.
We need a quick and dirty Radio controlled setup for testing ideas, and what I had in mind(for now) is using an old RC helicopter reciever and remote control. The only problem is, this thing only controlled 2 motors(1 for each part of the main rotor), and two servos(to control the pitch and angles of the rotors). What I want to do, is instead of having the RC controller directly control our robot, I'd like to use the output from the controller and input that into a Prop. This way, I can take the output from the servos and control something that is totally non-related to servos, i.e. control another DC motor and use the servo output signal to control the speed/direction. This interpretation would be done in the prop.
Does anyone have any pointers or a better way of going about doing this? Any ready-made objects for converting a servo signal into something else like a variable duty cycle PWM signal?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
John Abshier
Paul Baker
