Mac/Linux/Windows IDE - Ver 0.19.3 "Now with new improved PropBasic" release - Page 12 — Parallax Forums
191012141552
  • BradCBradC Posts: 2,601
    edited 2008-11-14 05:35
    Originator said...
    I see whats up, when you save as, there is no spin at the end on my PC, you must add it manually each time, but that works fine so I wouldn't bother.
    When you say "PC". Linux/Windows - Version?
    I'll make sure its fixed in the next release anyway.
    Pull my finger!
  • T ChapT Chap Posts: 4,260
    edited 2008-11-14 05:49
    Sorry, XP Pro
  • Chuck RiceChuck Rice Posts: 210
    edited 2008-11-16 17:49
    Brad, This code gives a compile error, but the cursor ends up on the wrong line. Mac Version, BST V0.12, Compiler V0.11
    con
      QPOS         =      $08            'Query Position
      QSPD         =      $10            'Query Speed
      CHFA         =      $18            'Check for Arrival
      TRVL         =      $20            'Travel Number of Positions
      CLRP         =      $28            'Clear Position
      SREV         =      $30            'Set Orientation as Reversed
      STXD         =      $38            'Set TX Delay
      SMAX         =      $40            'Set Speed Maximum
      SSRR         =      $48            'Set Speed Ramp Rate
    '--- User Constants & Variables ---
      AllWheels    =      0
      RightWheel   =      1              'ID of the right side Position Controller
      LeftWheel    =      2              'ID of the left side Position Controller
      CommPin      =      12             'communication bus pin
      BaudValue    =      32             'for 19.2kbps
      rxPin        =      1
      txPin        =      2
    var
      long         Wheel                  'Specifies which wheel to command for subroutines
      long         Distance               'Used to set the travel distance
      long         RxData                 'Used to receive data
    obj
      G             : "cr_Globals"
      encoder       : "FullDuplexSerial"
    PUB start : okay
    '' Starts uart object (at baud specified) in a cog
    '' -- returns false if no cog available
        okay := encoder.start(rxpin, txpin, %0000, 19200) : okay
    edited 2008-11-16 18:23
    Can you elaborate Chuck? I had to comment out
    G : "cr_Globals" but it gives me an error at
    (40,55) which is correct in my listing as the ":" between the ")" and the "okay"
    If I don't comment out the G : " cr_Globals" then it just gives me an error about being unable to locate that object with no line locations (which is a bug in itself really)
    Pull my finger!
    edited 2008-11-16 18:32
    The error is at the location listed in the message (I forgot to delete the ": ok" after I copied the start syntax from the object) . The problem was that I did not look at the error location numbers at first, I looked at the spot where it left the insertion point. This was 5 or 6 lines above the true error location. As a guess, maybe when it calculates the location to insert the cursor, it does not take the mac's two byte line endings?
    I can snap a screen shot if that will help.
    edited 2008-11-16 18:39
    Another problem. Annoyance really. I have the folding turned on, which is nice, but I often use a double click to select a whole word. When I do this on any word in the PUB line, it collapses in addition to selecting the word. It would be better if it only collapsed the line if I clicked on the [noparse][[/noparse]+].
    It would also be nice, if a double click on a word followed by a drag would select the second and third, etc. words in addition to the first word. Currently it selects the first word, but after that, it only ads characters to the selections.
    edited 2008-11-16 18:48
    More polish.
    A Triple Click on a line should select the entire line, including leading tab/spaces and the CR/LF. Currently a triple click only selects the words, so to duplicate 5 lines, I have to triple-click, then paste and fix, paste and fix, etc. I should only have to Paste, Paste, Paste, Paste, Paste.
    edited 2008-11-16 18:55
    Chuck Rice said...
    Actually, yeah a screen shot would help heaps here.
    As for the other niggles, I'll certainly look into them tomorrow for you and try to get them fixed before the next release.
    Ta for the feedback [noparse]:)[/noparse]
    Pull my finger!
    edited 2008-11-16 19:18
    Here is is. It may be that it is just not setting the cursor, so it is left wherever I had it last.
    Edit: The cursor does not show, but it is under RxData in the var section where the pink artifact was left.
    Post Edited (Chuck Rice) : 11/16/2008 7:23:50 PM GMT
    1465 x 992 - 305K
    err.jpg 305.5K
    edited 2008-11-17 05:37
    Just an opinion, when double clicking on the first line of the block to toggle fold or unfold, there are many times I double click on a word to highlight the word, and having the fold/unfold turns into a battle of wills sometimes. I will get used to it, but I think the fold icon is sufficient.
    edited 2008-11-17 06:00
    TChapman said...
    I've removed that feature and fixed the triple click line select that was bothering Chuck.
    The first was there by design. I don't use double/triple clicking to select stuff so I figured it was a good way to do fold/unfold. I'm obviously not correct [noparse];)[/noparse]
    I have to reproduce / fix the cursor being in the wrong place when highlighting an error yet, but I think I know where the problem might be.
    The double-click select word not selecting by word when you drag is something I'm going to have to get into the bowels of the editor code to fix, so it's not likely to happen very soon I'm afraid.
    There are enough bugs and annoyances there now to justify another release.
    Pull my finger!
    edited 2008-11-17 06:08
    Chuck Rice said...
    Quick question. Are you clicking on the error in the error box to highlight the error? It does nothing to the editor or cursor until the error is clicked on.
    Pull my finger!
    edited 2008-11-17 13:01
    BradC said...
    Oops. No. There is only 1 error, so I assumed that it would be selected.
    edited 2008-11-17 13:47
    Chuck Rice said...
    BradC said...
    No, it wasn't. I've set it up now so it will automatically select the first error though. Thought that sounded like a good idea.
    I've got a clipboard bug with Ubuntu 8.10 to finish and I'll have a new release out. It's proving to be a bit of a problem though so I'm not sure when I'll get it buried.
    Pull my finger!
    edited 2008-11-17 21:21
    This may be redundant:
    On XP using bst 12, I am experiencing that if I highlight several lines to delete, lines get deleted some number of rows below where I have highlighted. If I go to one line only, I can delete that line ok. This is with line number in on, and most code folded up except the few consecutive blocks that I am tweaking.
    Another observation:
    If I accidentally erase or leave out a ] or ) on a line, the compile error says 1,1 always, not the line that the error appears on. I have since learned how to work around these errors but thought I'd mention it in case you wanted all bugs listed.
    edited 2008-11-18 03:55
    TChapman said...
    I can't reproduce this one yet, but I'll keep trying.
    TChapman said...
    Wow, can't believe I missed that one. It's an ugly artifact of the way I parse brackets. I'll make sure its taken care of. Thanks!
    Pull my finger!
    edited 2008-11-18 04:35
    BradC said...
    TChapman said...
    I have seen something like it. If i quadruple-click on a line, it will select the whole line including leading whitespace and the line ending. if you then press delete, it deletes that line and the following paragraph. This was in the Mac version, and I was deleting a comment line. Undo undeleted all the deleted lines.
    @Brad,
    Despite the minor issues you are already working on, just wanted to say "THANK YOU" for a fine
    editor/compiler for Linux. I'm using it exclusively now for all my spin projects.
    Thank you for all your hard work on this...
    OBC
    New to the Propeller?
    Getting started with a Propeller Protoboard?
    Check out: Introduction to the Proboard & Propeller Cookbook 1.4
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card connected? - PropDOS
    edited 2008-11-18 07:00
    Chuck Rice said...
    BradC said...
    TChapman said...
    Nice catch! Quad click is "Select entire paragraph" and it was only highlighting the first line as selected.
    I've rectified that now, let's see if that fixes it for TChapman also.
    Pull my finger!
    edited 2008-11-18 07:21
    Oldbitcollector said...
    @Brad,
    OBC
    Cheers OBC, I really appreciate that.
    I don't mind the bugs so much, it gives me a reason to procrastinate doing block intent markers [noparse];)[/noparse]
    Pull my finger!
    edited 2008-11-18 16:24
    Version 0.13 up. Changelog in top post.
    Mostly bug fixes. Nothing visibly major but a bit of re-architecting.
    Think I have squashed all the bugs to date. Quadruple click to highlight paragraph does not seem to work on Mac (I don't see that as a problem as I'd never really intended it to work).
    Still occasional serial problems on windows and the serial terminal still has the reset-on-disconnect on Mac.
    I've tried to improve the error reporting in the compiler and I've managed to speed it up a bit again. I think I've pretty much wrung all the performance out of it I can now without a fairly major redesign.
    Pull my finger!
    edited 2008-11-18 17:27
    As always, Every release is better and better! Thanks Brad!
    edited 2008-11-18 17:43
    Chuck Rice said...
    Cheers Chuck! I'd be worried if they were getting worse, although I really have an uneasy feeling about this release for some reason.
    I'm not sure it's been as heavily tested as I usually get time to do and there was some pretty major voodo changes internally in the highlighter.
    Time will tell I guess.
    As always, bugs and feedback warmly welcomed.
    I think I've reached tipping point now. I was writing bst to help me write spin code, but I now seem to spend more time on bst than I do on the propeller itself. Hopefully things will start to settle down soon and I can get back to bashing out bytes [noparse]:)[/noparse]
    I'm thinking about adding a native Linux-x86_64 compile based on Ubuntu and GTK2 (same as now just native 64 bit) to the builds. Would there be any interested parties?
    Pull my finger!
  • AleAle Posts: 2,363
    edited 2008-11-18 17:47
    Brad: I noticed that there are a couple of things (No show stoppers of course):
    If you exit with the mouse pointer to the right of the end of the BST window it stays in "enter text mode".
    The buttons in the config dialogs are... hesslich! I mean, on the Mac version they are not standard apple issued buttons.
    In the list of filenames to the left, sometimes the names are painted in white with withe background when you use the scroll bar on the text editor, difficult to reproduce.
    If there is just whitespace in the top line, it will be painted with different colors depending on the section you select (independent of the color it has).
    Mac: If you close it from the close button on the top left of the window it closes the application... it shoudn't, well most apps just hide themselves, except the c1sco vpn client...
    btw. It is just great, and gets better and better !
    Edit: I just noticed that I used the same expression as Chuck, well it gets wtf, great!
    edited 2008-11-18 18:38
    Ale said...
    Can I ask you to elaborate on this a little more? I'm not quite sure I understand the nature of the problem.
    If I exit what?
    Ale said...
    Actually, believe it or not they are apple supplied buttons (Ugly, I agree completely - but Apple supplied none the less). Carbon has a bug in 10.5 where a button encapsulated in a panel component does not look like a nice normal OSX button. It looks ok in 10.4 though.
    I could get around it by re-designing the UI to avoid the use of panels, but that just makes my life a lot harder for some nice looking buttons.
    I figure the configure dialogs are not day to day kinda things, so for now they can stay ugly. My development machine is still 10.4, so they look ok here [noparse];)[/noparse]
    I know Apple is deprecating carbon, so I'll have to do something about it eventually.
    Ale said...
    I'll look into this one. Which particular version of OSX are you using (for bugs like this even the point release matters).
    I've never seen anything like it here. Are you talking about the file tree up the top or the file list down the bottom?
    If you ever manage to catch it, I'd positively _love_ a screenshot of it happening.
    Ale said...
    Oh neat, I'd never noticed that one. Now I've seen it I know why it happens and it should be a pretty easy fix. (Famous last words - the GTK2 cut and paste bug took me 16 hours)
    Ale said...
    This is the sort of feedback I really need from Mac users to make sure I can "Macify" things properly. Thanks! I'll look into how I might fix that.
    Ale said...
    Thanks, I _really_ appreciate the feedback. It's only because you guys are so good with bug reports and feedback that it gets better. I miss or learn to ignore lots of this stuff in my day to day usage. I need to be slapped around the bonce with it from time to time to motivate me to find and fix it.
    What started out as a quick and dirty ~3K line hack on top of a 10K line compiler is now in excess of 26K LOC. Bugs happen! [noparse];)[/noparse]
    Pull my finger!
    edited 2008-11-18 18:57
    All this happened in Mac OS 10.5.5
    The issue is the mouse pointer not changing from edit mode (That sort of upper case 'I') to the arrow.
    Are you using Carbon ? well, they are not gonna fix it! :-(
    I tried to reproduce that painting problem... so far no luck... as soon as I can I'll post it.
    You got in a couple of months much more than you know who, even after we begged and promised to pay for it. Well, let's enjoy !, thanks.
    Ale
    Post Edited (Ale) : 11/18/2008 7:38:59 PM GMT
    edited 2008-11-18 19:31
    This solved all my known XP issues, other than a rare unexplainable crash that I can't pin down the action that prompts it. It seems to follow a condition where the window stops scrolling properly with the mouse wheel, where the screen sort of jumps a bit but doesn't scroll, although the slider will still scroll it. Could be a computer based issue, I usually solve it with quit/start on the bst. Not a big deal, except cases like last night I didn't save for a while. I love the response on relaunch, "it seems we are recovering from a crash", to which I want to say "yeah, true, and how bout putting my stuff back the way it was prior please" [noparse]:)[/noparse]
    Love the new red parenthesis.
    edited 2008-11-19 00:52
    Just download .13 for linux.. Copy & Paste works perfectly! Thank you!
    OBC
    edited 2008-11-19 06:51
    TChapman said...
    Is this a new bug or an old bug? I ask as I've made some not insignificant changes to the internals of the highlighter in this release, particularly around memory allocation.
    If it's a new bug that will narrow it down for me to try and fix.
    Pull my finger!
    edited 2008-11-19 07:05
    On XP .12 was crashing, often it says a popup error that says "press continue if you want to risk......". If I press continue, things seem ok though.
    I also got the same crash tonight too on .13, it usually is having to do with deleting stuff (or backspace maybe I forget what does it).
    I noticed some things tonight new, clicking on the "+" fold down icon was folding blocks several blocks lower. It seems that deleting lines, or parts of lines of a block is weirding out the fold feature as described, but this is a guess. I did notice that once I hit Fold All Blocks it seems to rid the strange problem of blocks getting un/folded lower than the block I am clicking on.
    The crash seems to follow certain conditions, I am getting closer to identifying those conditions, or at least trying to track the preceding motions that led to the crash.
