motor interference
I am looking for ideas on how to keep motor noise from killing the Propeller.
I am using a 7.2v nicad battery. regulate that down to 5V. Then I have 2 separate 3.3 v regulators.
One for the Propeller and one for the motor.
Even if I run the motor at minimal voltage (using a Pololu smc02B dual H bridge) it stops the process running on the propeller.
The problem only happens if the motor is actual spinning, its not the static load.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
When you say "killing the Prop", you mean resetting on low power? Or the noise affects communication from and to the Prop?
I attached the schematic.
I tried using 7.2V to power the motor, and adding bypass caps on the prop and at the motor.
I also tried adding big electrolytic cap on the motor supply voltage.
When the motor spins the prop resets.
I have tried pulling up the reset pin.
I appreciate the ideas.
You need caps on every device, especially .01's near every Prop 3v3 pin, all other Vcc.
1- Don't abuse with the electrolityc capacitors value, instead add 0.1uf very close propeller and motor power supply.
2- Use separate power suplies as recomended Leon.
3- Try to opto isolate the control pulses from the pack motor/cnotroller to the propeller, and forget.
Regards.
Alberto.
