for the holiday — Parallax Forums
for the holiday
HumanoidoHumanoido Posts: 5,770
edited 2010-12-23 12:08 in BASIC Stamp
it.youtube.com/watch?v=2zDg6NfXpUo
It runs on a Basic Stamp BS2px code.
Just for fun, it has a big red nose, and the code to drive
it uses pulse width modulation to establish the analog
voltage drop across the jumbo red LED. Only two
connections, Vss and Signal... It has a cute factor,
so how can you resist? It's futile... [noparse]:)[/noparse]
humanoido
Post Edited (humanoido) : 11/13/2008 6:47:04 PM GMT
    edited 2008-11-14 22:25
    Humanoido:
    You are the undisputed, tireless, enthusiastic and inspired champion of the Penguin.
    My hero. Clearly, I need to get one ASAP. Where's that "Deal of the Day" button?
  • vrossivrossi Posts: 38
    edited 2008-11-15 10:08
    Humanoido,
    You are one of really few people who can show their talent both in terms of technical knowledge and in terms of imagination.
    Please go on with your excellent work.
  • SRLMSRLM Posts: 5,045
    edited 2008-11-15 16:32
    Now, all he needs are some BOE-BOT reindeer to pull his sleigh...
    edited 2008-11-16 15:12
    Thanks for the amazing comments. [noparse]:)[/noparse] You'd need nine reindeer BoeBots:
    Dasher, Dancer, Prancer, Vixen, Comet, Cupid, Donner, Blitzen
    and Rudolph. Penguin seems to have morphed between a Santa
    and a Rudolph. Did you calculate the pulling force of nine BoeBots?
    I think it's something like (2) * (9) * (49 oz/in) = 882 oz/in. or
    about 55.125 pounds of pulling force. SRLM, were you thinking of
    going airborne or was this a surface delivery of presents?
    edited 2008-11-16 22:23
    Perhaps the BOE-BOT could have an expansion pack: Ornithopter wings...
  • MikerocontrollerMikerocontroller Posts: 310
    edited 2008-11-17 03:04
    · Nice work, humanoido.· Will he be in issue #4?
    edited 2008-11-17 04:44
    He's in issue #4 on page 8. The Penguin Tech issue
    is waiting for completion of another youtube video
    and then goes into proofing.
    The main key here is the included software. In the project,
    Penguin has Aux 5 for a one pin expansion slot. I wanted
    to plug in one jumbo LED without soldering in the dropping
    resistor, yet needed to control the current and voltage to
    keep everything safe. The answer was built into software
    with PWM and the provided formula in the article. It's a
    kind of virtual dropping resistor, existing only in software,
    and a cool concept that can be applied to many other
    applications.
    If you wanted to apply Da Vinci's Ornithopter to BoeBot,
    you'd need to create some rather large wing pairs and
    may need to convert to a Super Carrier Board
    Item code 27130, to hard wire in the components.
    On second thought, convert the Boebot to a Penguin
    board and remove the wheels, servos, and chassis to
    make a featherweight construct. Let us know the results
    of your project. Strictly speaking, you may have better
    luck creating an ornithopter Penguin. [noparse]:)[/noparse]
    Just updating with some information for Christmas 2010.
    Quoting from here:
    http://www.robotinfo.net/penguin/PT/PT04.pdf
    Rudolph the Red LED Penguin! Get into the holiday spirit with Erco’s
    suggestion for a Red LED Penguin with a big red blinking nose. Just plug
    a jumbo red LED, short leg to (-), long leg to (s). The idea to defeat use of
    a current limiting resistor is by pulse width modulation in software. With
    LED on pin 5, code will blink the LED by gradually going from off to an
    increasing brightness, then repeat. Duty is a variable/constant/expression
    (0 - 255) that specifies analog output level 0 to 5V. It's set to a range from
    index 0 to 8, thus creating a voltage drop across the diode from 0 to .2
    volt. The volt equation is: Average Voltage = (Duty
