IR Beacon
I built my own IR beacon using a 555CN Timer IC· from Radio Shack.· I followed the instructions on "IR Remote for the Boe Bot" in appendix C.· So far I've been powering it with Vdd from the Boe-Bot which I believe is regulated 5 volts.· The package for the 555CN Timer states the the supply voltage is 4.5 - 16V.· If I power my beacon with a 9 volt battery, can I still follow the schematic from appendix C or will I have to calculate new resistor values?
The frequencies of the 556-based beacons I've built·are surprisingly insensitive to voltage changes, so I suspect your 555CN will operate about the same on 9 volts as 5.·Hopefully this is true for you, because you'll discover that 9 volt batteries don't last very long in continuous use, they'll be down to 7 or 8 volts before you know it. For a stationary beacon, you'll want to use a wall-wart AC adapter for power.
Jax
If a robot has a screw then it must be romoved and hacked into..
Parallax posesses power beyond belief.
Believe in it.
Function-wise, that 220 ohm resistor can be reduced or increased to change the beacon's output level. A single LED has a very narrow beam width (like +/- 15 degrees) so you may want to use multiple LEDs (each with its own series resistor) if you are using it for navigation. See an example of one of mine at http://www.botmag.com/articles/scribbler.shtml· . Too strong a signal will reflect off different items and your robot may track toward a ghost reflection. Better to use several moderate-strength LEDs fanned out in different directions than one giant one.
Jax
The IR LED will probably have problems with the current through the 220 Ohm resistor with a 9V supply voltage. You should switch to a 470 Ohm resistor to keep the current under 20mA. Some LEDs can handle more current. Check the datasheet for the LED.
Just curious about the 555 circuit shown. I'm familiar with the Scribbler's IR abilities, less so the BoeBot. If the Scribbler sees a steady 38 kHz beacon (such as the 555 emits), it only detects it momentarily, because its IR sensor expects a modulated carrier and its internal filter circuitry is not "continuous signal acceptable". That's why I had to use a 556 circuit instead of a 555. Is the IR detector in the BoeBot continuous signal acceptable?
It depends on the IR detector. The Panasonic one accepts a continuous 38KHz signal as far as I know. There's another one that Parallax sells and uses that does not.
Jax
Jax
