Controlling small AC loads with no relay.
Im trying to control neon from an SX without using a mechanical relay.... I can't have the 'click'. The neon will need to cycle every second on and off continuosly. Solid state relays don't work because the load is too small for them to function. the neon is 120VAC @ about .0015A. Straight transistor switch circuit? I'm never controlled AC with a transistor, is this the 'right' way? What is the best may of handling control of a very low current AC load?
Any pointers would be great!
Thanks again,
As a matter of brevity, the drawing doesn't include a fuse, but you ought to.
yes it is. Opto isolators are often used to directly drive relay coils, solenoids, lamps, etc. The only limitation is that the load current and voltage are within the device rating.
