Multi Dimension Arrays? Do we have them? — Parallax Forums
TJHJTJHJ Posts: 243
edited 2008-11-07 03:39 in Propeller 1
So I could have sworn I say something in the propeller manual about this, but I can not seem to find it again.
It C++ as an example, and if spin becomes C++, someone kill me.
SIZE_X = 10 SIZE_Y=5
int array[noparse][[/noparse]SIZE_X][noparse][[/noparse]SIZE_Y];
so really Ive got a 50 length array, that is accessed nicely from 0-9 and 0 -5.
Now for spin I tried defining it as
long array[noparse][[/noparse]SIZE_X] [noparse][[/noparse]SIZE_Y]
it doesn't like that.
So I keep wracking my brain and I cant seem to find a simple way to do this in spin. The best idea I have come up with is the following.
long array[noparse][[/noparse]50]
pub acessArray(x, y)
return array[noparse][[/noparse]x*10+y]
But that just seems fair as a solution at best, is there a better way to do this?
Thanks as always
TJ
  • mparkmpark Posts: 1,322
    edited 2008-11-07 02:35
    In regular Spin, that's pretty much what you have to do.
    Homespun does support multidimensional arrays. The syntax is arr[noparse][[/noparse]i,j] instead of arr[noparse][[/noparse]j].
  • TJHJTJHJ Posts: 243
    edited 2008-11-07 03:02
    Isnt BST using the homespun compiler? I keep getting a compiler error from it.
  • BradCBradC Posts: 2,601
    TJHJ said...
    No. The compiler in bst is released as a command line component called bstc. It's a completely different beast and does not support the multi-dimensional array extension.
    Pull my finger!
