Need some backlight options
I have a PCB where there are a number of holes drilled in it so that LED's can send light through to the other side of the PCB. The bottom of the PCB cannot have anything mounted on it, it mounts flush against a polycarbonate panel with graphics on it, no space. The LED must be on the top, but send light back through the board.
There are no U-Turn light pipes I can find. Rigging LED's to have a bend in the wires is rather jankie. There are LED's that exist that with flat wires called 'yokes' that would work, but no luck finding white in that style.
Any suggestions?
Any suggestions?
search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=475-1148-1-ND
In white:
search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=475-2700-2-ND
