Saw tooth output from LM34CAZ temp sensor
Here is one I ran into today.
I have 2 LM34s feeding signals into the two inputs of a LTC1298 ADC. A BS2 reads the ADC and outputs the temps to an LCD.
I noticed every once and a while that the temp reading on one of the inputs would start reading from 122 degF to 50 degF (readings updated every 3 seconds). I reseated the ADC, no luck, replaced the LM34, no luck. Finally I put a scope on the input and found a saw tooth wave for the output instead of a steady (varies 0.01 Vdc per degF) dc voltage.
The LM34 is soldered to one end of a 3-wire, shielded cable that terminates on a·Super Carrier Board. I also noticed that when I power the board up all is well until I turn on a power strip. This triggers the saw tooth wave even if nothing is plugged into it. I also get the saw tooth with only my scope lead attached to the output.
I took another look at the data sheet and it looks like I may need to add a 2K resister in line with the output or even add a RC circuit at the sensor end. The data sheet states this is for decoupling when feeding the signal into a high capacitance / high impedence input. I will assume for the moment that the LTC has high impedence inputs and the sheilded cable may be acting as capacitance.
By the way, the saw tooth is a fairly steady 37kHz, 0.6 V p-p.
I will try the decoupling circuits asap but was wondering if anyone has ever seen this before. I have used a number of LM34s without a hitch.
Any input will be appreciated.
Dave E
Dave E
Just an FYI.
Dave E
390 ohm LM34 output -----/\/\-----o--------cable to ADC | ===== 0.68 uF | ----common----▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Tracy Allen
www.emesystems.com
I bought some 2.2k today but didn't get a chance to try them.
The odd thing is, I have 2 sensors wired to the same type of cable, same length (+- an inch or so), same·ADC·and only one of them is giving a problem. The wave is still there but it dampens out within a few cycles.
Thanks again Tracy, I figured that you probably had some experience with these.
Dave E
