Help with PC interface and propeller
Could someone please help me. I am trying to write a program that allows me to a com port interfacing program like Hyperterm, PuTTY, or the Parallax Serial Terminal program. I wish to use the Prop Plug to facilitate this communication. I have tried using SimpleDebug.spin and FullDuplexSerial.spin but when i write a basic program to constantly send one test character, I get back nothing but garbage. Could someone please help me with this. I can't continue my project until I figure this out. Thanks
that might be of help to you.
Tell us a little more about what you are trying to do and share the code you are using.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
I've done this with no problems. Are you using a crystal or the internal oscillator? The timing is too precise for it to be stable without an external crystal or resonator.
SimpleDebug, written in Spin, also has a relatively low max speed. I've used it for 9600 bps with an 80mhz clock. It won't do 115,200.
Jason
OBJ
console : "FullDuplexSerial"
VAR
PUB main
console.start(31, 30, 0, 9600)
repeat
console.tx("p")
Include something like this at begin:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
Do you have the console line indented like above? If not, you'll only get a single "p"
What happens if you change the "p" to 65? Do you get a line of A's?
OBC
