IR sensor question
I would like to attach a camera to a servo and have the the servo rotate to allow the camera to follow an object in the room as the object moves. ·The object would need to be about 20-30 feet away. ·What is the best way to go about this? ·I was thinking of attathing an IR emitter to the object and have several detectors near the servo so that the servo will rotate to an angle depending on which detector "sees" the ir signal. ·Is it possible to have a stand alone LED sending a signal and willl they reach 30 ft? ·If there is a better way to do this please let me know.
The main problem I see is that the IR sensors are on/off sensors and Parallax changes the incoming IR light's modulation frequency to guess the range using the response curve of the IR sensor. If you use just an IR phototransistor as a detector, you don't get the benefit of modulated IR to reduce sensitivity to other light sources.
If you were using something like a CMUcam, that has provisions for tracking an object with a servo, you'd just need a contrasting visible color for the object to be tracked. You could combine the CMUcam and a separate video camera or webcam on the bracket. Look at Parallax's webpage for their CMUcam version:
www.parallax.com/Store/Sensors/CustomKits/tabid/134/txtSearch/cmucam/List/1/ProductID/29/Default.aspx?SortField=ProductName%2cProductName
Post Edited (Mike Green) : 11/2/2008 3:34:58 AM GMT
How about the point labelled P7?· And with P6, can I just connect it to a battery instead of Vdd?
